Raynald's Avatar
Question Hand Brake light is flashing ?
Hello All,
i have a small problem after to removed all gauge in my 911 1971,
my hand brake light is flashing all the time... maybe i have the wong wire on it ... i check the switch on the level and it work good
if some one want to check for me, what is the color wire on the light on the gauge ?
help will be apreciate !
Thank You
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 02-10-2003, 05:23 PM
it might indicate a problem in the master cylinder. not sure. the wiring diagrams on pp might help. the switches and gage is on the 2nd page on 71 models. looks like a brown wire with a yellow stripe. there are multiple connections, but my vision goes away when i look at the online diagrams.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 02-10-2003, 05:45 PM
Raynald's Avatar
Tryan, i have no wire to the master cylinder...
i am not sure about what is the good wire on the light...
i toke note about it but i think i have make a mistake about wire ground...
Thank You
Old 02-10-2003, 06:36 PM
the diagram is here
look at item 38 and 40 . from the listing it looks like a usa thing. ralph nader at work.
pull the handbrake(brown/yellow stripe) wire off at the dash and see if it still flashes. if it does not the short is in that wire. if she still flashes, follow the other wires on the diagram.
Old 02-10-2003, 06:46 PM
Raynald's Avatar
When i disconect the brown/yellow wire the stop flashing...
Ray
Old 02-10-2003, 06:53 PM
if you are disconnecting it at the dash and it stops flashing , the short/pinch is in that wire to ground or a bad switch.
if you are disconnecting it at the brake , its a bad handbrake switch.
Old 02-10-2003, 07:28 PM
Raynald's Avatar
Thank You , i will try tomorrow ...
Raynald
Old 02-10-2003, 07:31 PM
