-   -   Stupid Question: How do you tell if a cat conv has gone bad? (http://forums.pelicanparts.com/porsche-911-technical-forum/97774-stupid-question-how-do-you-tell-if-cat-conv-has-gone-bad.html)
alf 02-10-2003 10:32 PM
Short of failing an emissions test after waiting in line for 45 mins and dishing out $15, how do you know it is time for a new cat?
Kevin Stewart 02-10-2003 11:50 PM
I think they plug before they go bad, you may try bumping this in the morning, Kevin
speeder 02-11-2003 02:28 AM
I believe that the way they are tested is to remove threaded plug and measure pressure being released at that stage, this would indicate a plugged or free-flowing cat. When they go bad they plug up. If your car has been producing normal power, it's probably not your cat that is the problem. :cool:
AFJuvat 02-11-2003 03:23 AM
If engine temp continues to rise when the car is on the road (like on the freeway) is a good indicator that it is starting to clog up.
AFJuvat
osidak 02-11-2003 05:26 AM
I always thought the test was
Take it off look into it. If you see anything at all (honeycomb stucture ect.) then it was bad. All you have to do to fix it though is take a metal rod to it, cleans it right out. ;) ;) ;)
Of course I say this in jest
JackT 02-11-2003 05:32 AM
I think you can just take the car to a muffler shop and they can look at the temperature before the cat then after the cat and tell if it is bad.
Wil Ferch 02-11-2003 05:58 AM
Before and after temp is the factory method in the repair manuals.
---Wil Ferch
studeb 02-11-2003 09:38 AM
Before and after temperature
Before and after 4/5 gas reading
Cat temperature running, should be hotter than exhaust pipe
Exhaust pressure only tests for flow, they can fail and not clog. BTDTGTTS
dr.porsche 02-11-2003 12:47 PM
You can always tell when it's time for a new cat...it's when the old one is laying on it's back with it's paws straight up in the air and it's as stiff as a 2 by 4!! THEN, it's time for a new cat!!
alf 02-11-2003 02:34 PM
Funny.
Thanks for the responses, i do not think i need a new cat at the moment, just trying to find a good excuse to buy a new exhaust system. Honey, the cat is dead, if i am going to swap it out might as well get SSIs and a free flow muffler while i have the car up :)
don911 02-11-2003 02:49 PM
Save the $ on the new exhaust and just put in a cat by-pass pipe. You can do it for well under $300 and get about the same HP increase.
