LinkBack | Thread Tools | Rate Thread |
Removal of entire fuel line
Kindly regards Steen Larsen |
I used the technique from this posting.
I removed from the front and installed them by pulling from the rear. It will go thru that metal guide. You have the advantage if the steering rack is still removed (judging from your picture). How hard is it to change the fuel lines?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
If you still find it difficult you might want to check with Len (BoxsterGT here on the site). Also can make fuel lines to your specifications.
PJ 78 911sc Targa 70 911T |
![]() ![]() The factory installed these Tunnel lines from front to back, and to replace them they must come out at the front. Replacing is the same procedure unless you are installing my tunnel lines. I offer the same Polyamide Tunnel lines without the front hoses attached. Instead they have M14 fittings at both ends. I provide a Female coupler and this makes it a simple job to connect the (my) replacements at the rear and pull them through as you remove the original out the front. ![]() Once in place my replacement front hoses are installed. Not an easy task but much less difficult and time consuming than the originals. Len ![]() Last edited by BoxsterGT; 03-11-2018 at 05:32 AM.. |
Steen, Len's lines are excellent and have been used by many of us over here. The fact that he adds connections so in the future the rubber-only front and rear sections could be replaced, while leaving the polyamid tunnel lines alone is what makes them so cool. They are beautifully assembled from the best materials, and they go in perfectly, using the union Len provides to use the old hoses to fish the new ones through the tunnel. I did them in my 82 SC. I bet the shipping costs to you would be reasonable. Best of luck, John in Connecticut/USA.
Unless it seems if you use original type lines in a '74 or '75 which has a slightly crooked/bent end at the gas tank side. I way I see me pulling mine out is to use the weed wacker line and cut the crooked end off the front, and pull it through to the back with the new line from the front.
+1 Couldn't agree more, I just did the complete line swap yesterday. Took most of the day working by myself, but the products are excellent. Took 9 days for the package to get to me in Norway, will most likely be faster to Denmark. Feel free to ask if you need advice.
1981 911SC "Minerva" 2004 Boxster S, Seal Grey The slope is not slippery; in fact it is entirely frictionless. |
![]() ![]() steeen - From your photo it seems you must have a 911SC or Carrera but you never actually told us. Did you complete the fuel line replacement? Are you happy with the results? Len ![]() |
gearhead
Len,
Are you still doing lines? Your pm box is full...
1974 911 Restorod 1974 914 Bumble Bee 1975 911S Tom's Targa 2008 Cayman S Mule |
Matt, email him, he doesn't do PM. len.cummings (at) verizon.net
He just did lines for me a few weeks back, top notch.
gearhead
Thanks Evan. I wasn’t sure since he removed it from his signature.
![]() Hi Matt, If you add your email link to your member info I can email you directly. I do not use pms as we cannot send photos and its hard to track messages, at least for me being somewhat computer ignorant. Len Cummings ![]() |
![]() ![]() Hi Matt, Don't think I ever heard from you. Do you still need help or have a question re: fuel or oil lines? Len ![]() |
Gary R. |
Thread Tools | |
Rate This Thread | |
