1973911s's Avatar
oil pressure sender switch picture on a carrera
Anyone have a picture of the above part, so I can see if it is leaking. A search of the board talked lots about it, but no pictures.
1984 Carrera Targa Sold to fellow Pelican
1973 911S Targa - Sold to fellow Pelican.
Old 09-19-2004, 09:37 AM
Randy Webb's Avatar
The idiot light sender, or the pressure gauge sender? The latter looks like a tin can about 3" in dia.
Old 09-19-2004, 10:29 AM
3.2 CAB's Avatar
If it is the pressure gauge sender that you are talking about, on the carrera, it will be between the fan and the a/c compressor sitting on top of a little block that your tensioner oil line on the right side attatches to, if for the idiot light it will be at the top of the engine, at the trans end of engine. The little sender next to the "can" type oil pressure sender on the 3.2 is the temp sensor.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-19-2004, 12:21 PM
KCPSG's Avatar
If this is what your looking for, its the oil sender unit right next to the fan and kinda under the A/C compressor on the back edge of the motor.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 09-19-2004, 01:28 PM
1973911s's Avatar
Looking for a picture of the The idiot light sender, thanks for the information.
Michael
Old 09-19-2004, 01:37 PM
KCPSG's Avatar
the idiot light sender is the one w/the green and black wire attached to it. next to the oil sender.
Phil
1998 BMW 328i
Old 09-19-2004, 01:39 PM
1973911s's Avatar
Thanks, I am a novice at Porsche engines and need pictures, the car is going to the wrench on Tuesday.
Michael
Old 09-19-2004, 01:41 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Michael,
If you are looking for the oil pressure switch at the back of the motor, here is a pic (along with the thermostat and breather cover):
Missed you on the Ortega run today, we had quite a few people and than a great BBQ at Richard's.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 09-19-2004, 01:55 PM
1973911s's Avatar
Palph,
Thanks, I am hoping that is what is leaking.
I was bummed that I missed the run, but I did teach my daughter to case after some nasty geese in the park, it was priceless.
Michael
Old 09-19-2004, 01:59 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
No, that is the oil temperature sender!
1981 SC ROW Coupe
Old 09-19-2004, 04:37 PM
KCPSG's Avatar
Maybe I misunderstood what he was asking for, but in my Bently's manual (pp.170-6) it shows the oil pressure warning light switch.
Phil
1998 BMW 328i
Old 09-19-2004, 05:54 PM
Question idiot light
maybe I bought wrong part, glad this thread is here. My red oil pressure light comes on after driving awhile but druck pressure is good. I noticed my oil pressure gauge to the left of the druck pressure gauge is pegged all the way to the top when driving is it supposed too. Thanks, was told if red light comes on its your idiot light switch that is bad.
Old 11-19-2017, 05:55 AM
Nope.........
KCPSG,
The green/black shown in the above picture is the oil temperature sensor.
Tony
Old 11-19-2017, 07:39 AM
Technical error........
Unfortunately you used another technical error printed in the Bentley Manual.
Tony
Old 11-19-2017, 07:51 AM
Reiver
Reiver's Avatar
Your oil pressure is good.....what does it show and does it go up/down with your rpms?
The other gauge is your oil fill gauge.....when driving it normally registers nothing or barely off the bottom of the scale. It will only show 'about' what oil you have in your oil tank when at operating temperature, and at a standstill on level ground.....it is a rather worthless gauge.
If pegged all the way to the top you either have overfilled your oil (oil measured ONLY when at full op temp with engine running on level ground....only fill 1/2 way between the dipstick marks)
Or, more than likely the ground is bad.....you can pull the gauge out (press fit) and clean the wiring contacts and check your ground...ground is a brown wire on Porsches.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-19-2017, 07:54 AM
Reiver, thanks I'll take picture and show you what I mean, Boy, I'm sounding like a real moron when it comes to this car, thinking maybe I should stick to my musclecars.
Old 11-19-2017, 12:09 PM
Brew Master
cabmandone's Avatar
Don't sweat it, we all start somewhere. The fun is in learning along the way!
Old 11-19-2017, 01:25 PM
Reiver
Reiver's Avatar
No sweat....the aircooled 911's have their idiosyncrasies...but that is what gives them character.
De Oppresso Liber
Old 11-19-2017, 06:37 PM
