-   -   Removing sound deadening (http://forums.pelicanparts.com/porsche-911-technical-forum/978135-removing-sound-deadening.html)
steeenogann 11-19-2017 12:53 PM
When looking for possible solutions for getting rid of old sound deadening in my Porsche 911 from 1979 I have found several solutions heating up and dry ice. The best solution probably depends on the age of the car. Can anybody tell me which solution is the best for a 1979 Porsche.
http://forums.pelicanparts.com/uploa...1511124728.jpg
cabmandone 11-19-2017 01:37 PM
Looks like it's cracked and chipping so I'd use a putty knife and get up as much as you can then go to heat if necessary.
Ayles 11-19-2017 02:55 PM
On my 82 it was cracked and chipping like your photo. I used a petty knife and it pryed out in big chunks. There will be some residue to clean up for which I used a little citrus strip.
dlagerstrom 11-19-2017 04:14 PM
Yup. Same on my 82. Much came up with just a putty knife. Used a heat gun for some areas and that helped it come up in big chunks.
s5uewf 11-19-2017 04:40 PM
Get the cheap heat gun at Harbor Freight and it should come off like butter with a putty knife.
seafeye 11-19-2017 05:05 PM
Heat gun. Putty scraper and wire brush. Depending on how much you want to remove. http://forums.pelicanparts.com/uploa...1511139939.jpg
steeenogann 11-19-2017 06:26 PM
New sound deadening material
Thank you all for very informative answers, it's appreciated. I also need information about what you did to renew the old sound deadening material. All information about brand name or even item numbers will be very much aprreciated. Again thank you for your help.
Ayles 11-19-2017 06:30 PM
I didn't replace it with much. A lot of opinions here on products like dynomat so many threads to review.
steeenogann 11-19-2017 06:51 PM
But I would like it to look original, and Dynamat is probably not the original material?
jimtweet 11-19-2017 07:17 PM
http://forums.pelicanparts.com/uploa...1511147837.jpg
Dry ice. Period. Takes 15 seconds to remove all deadening
jimtweet 11-19-2017 07:19 PM
http://forums.pelicanparts.com/uploa...1511147921.png
Speed metal 11-19-2017 07:33 PM
This!
Its soooo easy and fast this way it feels like you're cheating;)
Tremelune 11-22-2017 04:56 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/843461-interior-sound-deadening-noise-reduction-thermal-insulation.html
steeenogann 11-25-2017 12:40 AM
Thank you Tremelune for the very informative article, my problem is that I am more interested in the origianl look, and not the very best sound deadening effect. So, if anybody could send information about the original material Porsche used for 911 in 1979, I would appreciate it very much. But again, thank you for replaying.
