Where can I find this fuel fitting?
I have 4 48 IDA webers on a project and need several of these brass fuel fittings. This one was in a box of misc fittings and I don't know what it used to fit. Thread is 12X1.50, and the tube is 8mm OD. It has a straight thread, not tapered and uses a sealing washer as pictured. Not having any luck yet searching online. The ones that look similar are all larger. Any help is much appreciated.
206 637 4071
Old 11-21-2017, 05:37 PM
Fuel fittings........
John,
Have you tried Len Cummings (BoxsterGT). Best to give him a call to get in touch with him. He is busy relocating to his new place in New Hampshire. If you need his telephone number, PM me.
Tony
Old 11-21-2017, 06:18 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Carbs Unlimited? Fittings for Weber IDA Carburetors
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-21-2017, 06:26 PM
al lkosmal's Avatar
Try Bel-Metric John.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 11-21-2017, 06:30 PM
I don't see it on either of those sites. I don't want to go AN. I see the aluminum blocks on Carbs Unlimited, which I already have, (from Pierce Manifolds) but no brass piece to screw into it. Trying to keep it simple.
206 637 4071
Old 11-21-2017, 06:38 PM
al lkosmal's Avatar
Does it need to be brass?. If not, this looks to be the right size or very close.
Vibrant Performance 11412: Metric Male to Hose Barb Fitting Straight | JEGS
regards,
al
RGruppe #669
Old 11-21-2017, 06:40 PM
Google: 12mm x 1.5 to 8 mm barb.......
John,
Found a bunch of metric fittings you need.
There are more choices available.
Tony
Old 11-21-2017, 07:23 PM
Looks like boh of those are aluminum. Rather have something stronger. Fussy I know.
206 637 4071
Old 11-21-2017, 09:21 PM
proffighter's Avatar
Tada!
https://www.turbozentrum.de/en/connection-parts/hydraulics/screw-in-adaptor-tubefitting/einschrauber-mit-schlauchanschluss-m12x1-5-zu-7-5mm/a-3111/
Roland
930 Turbo '81 Too many modifications to list
Old 11-22-2017, 05:06 AM
The original pictured fitting appears to be yellow zinc plated steel not brass. Sorry but I don't have any information for a source.
Old 11-22-2017, 06:09 AM
steely's Avatar
Maybe BAT Inc? British American Transfer
fittings listing
http://www.batinc.net/mocal.htm
They have plated steel fittings, but I didn't look hard.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-22-2017, 07:12 AM
devalued member
juanbenae's Avatar
try royal brass Hose, Hose Assemblies, Fittings and Hydraulic Adapters in San Jose
75S slick-lid webered, early n spicy 3.oL hotrod wanabe
(build thread >) http://forums.pelicanparts.com/california-southwest-us-az-nv/443725-plunge.html
Old 11-22-2017, 07:26 AM
fitting
Try Earls Aeroquip Supply in Md.Fred
Old 11-22-2017, 07:51 AM
