How to remove driver's seat: 1977 911S
Any tricks to removing the driver's seat in a 1977 911S ? Do the rails have to come out with it?
Thanks, Roger |
Remove all the bolts in the sliders.
Run the seats forward, remove the six mm bolts (2)
Run the seat back and remove the two front bolts That’s it Bruce |
I was just messing with my seats yesterday, bolt heads were 10mm and there wasn't a lot of height available for the two rear bolts. I took a cheap 1/4" drive 10mm socket and shortened it up with an angle grinder, used with a small 1/4" breaker bar, it would fit in the space.
77 911s 16 981gts |
