electrical demons
I have a great 85" Carrera that purs like kitten but... After long driving or hard driving my battery light will flicker slightly at idle. It doesn't last very long but you can feel it, slightly, in the engine. I replaced the battery 2 months ago and I fear there could be a repeat performance. It starts right up and the engine has never died on me.
Could this same problem be related to my tach having a mind of its own sometimes and my clock never keeping time?
Any feed back would be great.
Old 02-11-2003, 07:29 PM
check you voltage with a meter. you can get a cheap one at walmart for 10-15 bucks. 12.6 or so with the car off. 13.6 to 14.6 running.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 02-11-2003, 07:40 PM
If the (engine running) voltage at the battery terminals is weak, check that the grounding strap connections are clean and the belt tightness is correct. If they're fine and the battery is good, check out the alternator/voltage regulator.
Argo
88 Targa
Old 02-11-2003, 09:55 PM
You do not have permissi
john70t's Avatar
One idea would be a common ground for the instrament lights being loose and the return backfeeding through the others. I'm not sure if you're vehicle has a printed circuit board, probably not.
Another idea is the car is running a tad rich/out of adjustment and the low idle is bliping the light.
There was a post similar to this quite some time back-mabye other 3.2s have similar situations.
Old 02-12-2003, 05:01 AM
Huey581's Avatar
I had a voltage problem with the transmission ground strap. It had rusted just enough to affect the voltage. It is on the bottom of the
transmission and is exposed to the elements. Mine cost $ 15.00 bucks
and my crazy tach, clock, and shift light problems went away!
Huey581
86' 911 Cab
Old 02-12-2003, 05:07 AM
