-   -   Another backup switch question (http://forums.pelicanparts.com/porsche-911-technical-forum/978739-another-backup-switch-question.html)
bcgreen 11-25-2017 12:07 PM
On a '76 911 I've taken the trans. support bracket off and am ready to remove the backup switch but the speedo cable connects right next to the switch. I can get a wrench in there but cannot move it because of the speedo connection.
For you guys who have done this job, did you guys undo the speedo connector?
Bill Verburg 11-25-2017 02:31 PM
I can't answer your question but I did learn something new here. I never knew the MFI '76 Carrera 2.7 still had the mechanical speedometer drive. The '76 3.0 Carrera all came w/ an electric speedo.
bcgreen 11-25-2017 02:47 PM
I don't know what a electric speedo looks like, all I can say is that in my situation, a cable runs adjacent to the backup switch that I am saying is the speedo cable. I can post a pic. if you like.
Bill Verburg 11-25-2017 03:15 PM
I understand what your predicament is, my '72 had the same arrangement.
It's just that the '76 2.7 Carrera came w/ a 915/43 w/ the older style mechanical speedo
the "76 Carrera 3.0 came w/ a 915/44 w/ electric speedo
I had always assumed that all the '76 Carrera's used the same trans, I was wrong.
bcgreen 11-26-2017 06:40 AM
Here's a pic of my dilemma.
http://forums.pelicanparts.com/uploa...1511707230.jpg
gomezoneill 11-26-2017 08:29 AM
Pull the speedo cable then use a combination wrench to loosen the switch. Either open end or box.
bcgreen 11-26-2017 08:48 AM
Are you pulling the wires off of the switch with needle nose?
