-   -   how to take out the pedal assembly please? (http://forums.pelicanparts.com/porsche-911-technical-forum/978906-how-take-out-pedal-assembly-please.html)
manuyc 11-26-2017 05:27 PM
hello anyone can chime in on how to dis-assemble the pedal assembly from the car? i have a 81 sc targa So I can clean it up. thanks
toomany911s 11-26-2017 07:11 PM
I sent about 10 minutes writing a "How to" for you, then on checking a small fact I remembered Wayne had posted a how to on Pelican, so here it is....
Porsche 911/914 Pedal Cluster Rebuild | 1965-1989 | Pelican Parts DIY Maitenance Article
john walker's workshop 11-26-2017 08:18 PM
A tip for making the job easier is disconnect both the flat bar and the long round rod at the top and remove the cluster with both pieces attached. Mark the angle of the flat bar and reassemble the same. Reinstall the assembly same as removed.
manuyc 11-28-2017 03:46 AM
thank you guys! I really appreciate it.
manuyc 11-28-2017 03:52 AM
one question i do have is how to take it out from the floor pan? is it just two screws in front of the pedals or is it also the two screws on the fire-wall? thanks
yelcab1 11-28-2017 05:59 AM
Two more bolts from UNDER the car.
911pcars 11-28-2017 02:55 PM
Try here for most all repair answers:
Porsche Workshop Manuals
manuyc 12-03-2017 04:42 PM
thanks
