911sc stalling problem
I hate that this how my air cooled ownership is starting, but I’m having a problem with a 1978 911sc that I just purchased.
The car was great on the test drive. When cold started it idled a bit high but would settle into a nice 1k idle after a few mins. On the hour drive home it was good on ther freeway, with just a few bucks at 2500 while cruising. When I pulled off at my exit problems started. I pushed in the clutch to coast to the light and the car just died. It started back up, but would die every time I came to a stop. I was able to make it home. I left it in the driveway for 10 mins or so then went to pull it into the garage. It fired right up and idled with no problems. I took it for a drive a few days later. It was great again until it got warm, then it was the same problem. I’ve been reading up on the CIS for the last 3 days. I did pull the oil cap and the idle dropped a bit but I don’t have the tools to properly diagnose the problem so I’ll likely take it to a shop, I just want to make sure I know what I’m talking about when I got in there. I get the feeling that one of the valves in the CIS is sticking because the car wasn’t driven that much. I just wanted to see if I’m on the right track of if there is anything minor I should try before taking it in. Also, I’m not afraid to pull anything apart and rebuild it, I just don’t want to be throwing money at it when I’m not sure what problem is. |
probably too rich.
hi idle when cold is good. drive it with the oil cap off. you can remove the air filter and pull down on the sensor plate at idle to lean it out. if it idles better it is too rich. if at idle, it starts to surge it is too rich. invest in a set of pressure gauges. one other thing. you may have 2 vacuum hoses going to the warm up regulator(WUR). one should have vacuum on it at idle. if not that will make it run rich too. |
Could be an ignition problem. You are describing a common CDI failure mode. It shuts down when car gets warm.
Is the coil black or silver? |
Coil was my thought also.
it starts right back up from what I gather.
the coil needs to cool before it starts back up or it will act like it is trying to fire up but wont. IE, it dies at idle |
Thanks for the quick responses.
I'm 90% sure coil is black, I'll confirm when I get home. After it dies it will fire back up, warm. If I keep some throttle on it I am still able to run and drive. Its only dying when no throttle is applied and it attempts to idle, while warm. Once it cools down it idles with no problems. I'm also reading this (911 CIS Primer - Components) while "working" and trying to come up with a short list of things I can troubleshoot w/out doing a fuel pressure test. Replacing some of the "cheaper" items isn't a problem. I just want to avoid having to buy a rebuilt WUR or FD if I'm not sure they will fix the problem. |
Confirmed, black coil. Blue Perma-tune CD.
Hi, I have similar issues with my 78. I have an appt with a garage to check it out (mixture) as I have guages and all pressures are ok. I will post back in a few weeks after the appt.
By the way, I can get me car to not stall if I brake to a stop light and leave it in gear to slowly bring the revs down to 1100 ish. Then when I put in the clutch, it idles fine |
First and foremost, welcome to the Pelican Porsche community and P-car ownership!
Second, and probably most important…when was the last maintenance done? Check the records which came with your car since they will provide you with very useful information about the care taken prior to your ownership. You may find that the car just needs a little bit of adjustments, such as: 1) a tune-up 2) new components (spark plugs, air filter, fuel filter) 3) valve adjustment 4) Timing set 5) Oil change By what I gathered from your information posted here, your idle should settle around 950 rpm when the car is warm. One thing to check is the distributor itself…does it move when you try to rotate it to the left or the right? If it does, this could be a problem and there is a nut that can be tightened up to secure the distributor from moving while driving. Just a thought. Do you have Wayne's book 101 projects, or the Bentley Manual for the 911SC? These are good sources for information, as well as the Porsche Factory Manuals. As mentioned above, the CDI system could be the culprit but I hope not since that is expensive to diagnose and replace. When you turn the key on, there should be a high-pitched whine coming from the engine compartment which indicates the CDI is working. I do hope it is something basic and not something major which provides the fix. Good luck with your investigations and have fun with your car. SmileWavy |
Thanks for the warm welcome, I appreciate everyone patients while I figure out how the new car works.
It was maintained regularly, but could absolutely use a good tune up, valve adjustment, etc. Right now I’m just trying to get it running long enough to smog it and transfer the title. Once that’s done I’ll give it a whole once over. I’ve also noticed that there is some play in the fan belt. It’s got a wobble while running and I can deflect it about an inch. I’m guessing that’s out of spec, not sure if it can cause this problem. |
Oh and this is actually my second p-car, but my first air cooled.
I call it an obsession, my wife calls it an expensive problem. :) http://forums.pelicanparts.com/uploa...1512097692.jpg |
Pulled the fan pully off to see if I could adjust the tension on the belt. Only 4 shims all on the inside. :(
I get the feeling I’m going to find all sorts of fun things while I get this thing fixed up. |
With it idling, take the oil cap off, does the idle change? If not, you probably have a decent sized air leak letting unmetered air past the sensor plate.
Should it be dropping more than that? |
I agree with the possibility of it being overly rich now that more information has been posted.
Not sure about the Permatune CDI’s failure mode characteristics. You are lugging the motor at 2500 rpm... they don’t even start to breath until 3200 rpm.. :) |
If you post your location in your signature block it may prompt a local Pelican to come over and help. Someone familiar with these cars can do a quick diagnosis that might take you much longer to discover. The solution could be something as simple as turning out the idle screw.
Do these two screws come out of spec that often? I spoke with the PO and he had been going on 100+ mile trips every few months without issue. |
check for power at the WUR connector
check power at the thermo time valve(TTV). check vacuum at the valve at to the WUR |
I’m guessing I still have a few vacuum leaks I need to hunt down. |
Welp, good news bad news.
Took it to the smog shop and it passed, but it was only because the guys were cool about it stalling a few times. I can at least get it registered and insured. It's back to square one. From what I can gather the troubleshooting process is this: Vacuum Ignition Fuel CIS components I'm curious, are there any numbers from the smog test that would help me better understand if the car is running rich/lean? |
The emission requirements on your 78 vs that water cooled devil are night and day. Far less stringent on the 78. If you are hell bent on not springing for pressure gauges, the absolute core of CIS functionality:D, I would focus on air leaks. There is one thing I will throw out here for grins. The deceleration valve on my 81 is designed to bleed air into the air box if you lift throttle at high rpm. The high vacuum opens the diaphragm. As rpm's decrease the diaphragm should close. I can put a golf tee in the small hose that feeds the unit and eliminate it from the system. Not sure if it's that simple on the 78. Your's is a little different. |
do you have the CO reading?
Good news, its running great now. I replaced plugs, wires, dist cap, rotor and coil. Most seemed near original and well past their useful life.
Next up is the vacuum lines. I picked up a bunch of 3.5mm line but it looks like there are a few other sizes in there. I searched but couldn’t find a definitive chart of what else I’ll need. Does anyone know the other sizes? |
Vacuum lines. I snip 10mm of the ends and refit. It seems to work well. Another thing to do sometime is to replace the fuel filter.
I'm pleased the car is running well and you can get out there and enjoy it. It's a great looking car. |
:( False hope. Took it for a longer drive on the freeway this morning and the problem came back.
Time to pick up a fuel pressure gauge. Which one do you guys recommend? |
I am not sure if the '78 SC has this, but I had an issue with my O2 relay under the passenger seat going bad and exhibiting same symptoms on my '80 SC.
Here's a thread on it... with the part number that worked for me. (although if your relay has that plastic tab on it, you might want to order the other one on the page) http://forums.pelicanparts.com/porsche-911-technical-forum/728026-rough-running-green-wire.html |
for one year and NOT for a 911SC. |
Intermittent problems that involve heat seem more like an electrical or ignition issue. The Permatunes are notorious for intermittent failures, although usually they require a bit of time to cool before they restart. If you crank and it doesn't start right away, get a timing light on it to see if you're getting spark. |
Decel valve and O2 relay not present in the 78 CIS.
When it does die it’s when the clutch is in as I pull to a stop. From there it fires right back up and will run as long as I keep some throttle on it. I also noticed that it’s blowing a pretty large cloud when I first start it cold. Not sure if that’s related or normal. I know a little smoke is typical but this is like a solid 10ft radius. Blew it straight across the street this evening. |
Ignition components doesn't seem like the right direction to me. I would expect if there really was a problem with the ignition, that there would be other symptoms.
What is your idle speed? Where is your timing set? Does your distributor have one vacuum line or two? I think the early SC only had one, for vacuum advance. |
I plugged the vac line that ran from the throttle body to the smog pump control (Diverter Valve?) because it was cracked and leaking. Ever since then it has a huge cloud of white smoke when I cold start. Makes me think that the mixture was rich to cover up for some of these vacuum leaks. Much of the parts on the motor are original. Is it crazy to consider just dropping the motor so I can easily replace all of the vac and fuel lines? Oh and your question about the idle, it seems a little high, hovers just above 1000 and occasionally will drop to 950. Distributor does only have one line. I'll have to check on the timing. |
You have got to get all the vacuum / air leaks out of the system before you start doing anything else. Sounds like you have a lot of old rubber; old rubber splits and leaks, and with the sheer number of vacuum-controlled bits on these SC engines, you're chasing ghosts until you get real certain that all the air leaks are gone. Unmetered air can cause you to run lean, and if you adjust mixture while you have unmetered air, you'll be off again as soon as you fix the leaks.
There are some tricky leaks in hoses that run behind the CIS and fuel distributor. Also, check the rubber boot on your CIS and your airbox itself - those can leak too. Good luck! A smoke machine or a cigar can really be of assistance with this. |
Haven't seen this asked/answered here - does RPM drop when you remove the oil filler cap with engine running?
My goal is to replace all of the lines. I purchased a bunch of 3.5mm line but it appears there are a bunch of different sizes. I couldnt find a straight answer on what I need to order. The next challenge becomes, how do I get to all the lines on the back side of the motor. |
Hello There:
You can get to most of the smaller lines in the back of your CIS system by doing a partial engine drop. Hope this helps and Good Luck!SmileWavy |
| All times are GMT -8. The time now is 03:10 AM. |
