gregk1's Avatar
2.4S P&C on a 2.7??
Would a set of 2.4 S p&c work on a 2.7? or is there a differance in the stroke of the crankshaft. I know a guy that has a set of good used ones I might be able to get for a fairly good price
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 02-12-2003, 08:49 AM
They would except that the 90mm pistons and cylinders onthe 2.7 have a larger diameter at the cylinder base than the 2.4 has. You could bore those spigots from the 2.4 size to the 2.7 size, but you can't go backward.
If you can get the 2.0, 2.2, 2.4 case, your in business though.
2.4-2.7 crank/rods are the same
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 02-12-2003, 08:54 AM
gregk1's Avatar
Ok thanks
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 02-12-2003, 08:57 AM
dtw dtw is offline
GAFB
Not to put too fine a point on it, but you would be decreasing your displacement to 2.4 (reducing the bore).
Several BMWs
Old 02-12-2003, 09:09 AM
