1977 911 sitting for 18 months
My cars been on a battery tender for the past 18 months. Battery is I think about three years old. Tried to start, but nothing. Had to jump start, and that took a while as well. I always check the tender and it’s been green the whole time. If the battery is bad, will the tender turn to red?
Also I was dumb and tried to start the car with the old fuel. It did not like that! Should I siphon the old gas out? It did not want to run, and made some very bad noises!
I feel bad for neglecting this car, and I’m hoping to stay on top of it. Problem is I don’t know where to start with repairs. Has a bad oil leak coming from I have no idea. Also, Porsche parts are getting so expensive I’m a bit discouraged!
Sorry for the rant.
Old 12-10-2017, 08:00 PM
Yes change the gas, lots of threads on starting a car that has been sitting, use the search function to find them. used parts can always be gotten for a good price on Pelican.
Old 12-11-2017, 02:43 PM
Open Highway Productions
Mad Max's Avatar
The gas is bad and needs to be replaced.
The battery issue maybe a bad ground/ignition.
Are you near eastern Tennessee? If yes, I would be willing to give a hand.
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 12-11-2017, 02:57 PM
Administrator
Dmitry at Pelican Parts's Avatar
Sorry for the rant.
Hello and welcome to the forum! As the above member suggested, there are quite a bit of threads on this topic; I've attached a link below to one that you may find helpful. Please let us know if you have any other questions or if we can assist with any part needs. Take a look at our DIY tech articles below as well!
Starting a 911 that has been sitting
Porsche 911 (1965-1989) Technical Articles - Pelican Parts
sugarwood's Avatar
Your first step is easy
Here are some photos from when I removed my gas tank.
Remove the fuel sender from the top of the tank. Five 9mm nuts.
I pumped out all the gas using a hand pump.
Worked great and only took about 1 min. per gallon.
1986 Bosch Icon Wipers coupe.
Old 12-11-2017, 03:52 PM
Thanks everyone.
Old 12-11-2017, 03:55 PM
I did the same thing removing the gas and used a coat hanger with a rag attached to it to remove all after pumping it out.
Old 12-11-2017, 05:01 PM
