A/C condenser fan in trunk
Does anyone make a block off plate for the frunk mounted condenser blower?
I've got an 84 that had 75% of the system removed and they pulled the blower but left the condenser. Going to pull the remaining bit out and block off that rather large hole |
I made one out of aluminum, painted it, used a neoprene tape to seal it and riveted it in. I did not find a pre-made solution.
You’ll have to make two plates to seal off the area where the front condenser blower was located. I think some light gauge aluminum plate could easily be formed to these shapes.
I didn't seal the forward hole just yet...I might use it for fresh air ducting to the central dash vents. I just sealed the lower hole.
Thanks for the suggestions guys
Post 168 on this page to see what mine looks like:
http://forums.pelicanparts.com/porsche-911-technical-forum/819396-so-how-backdate-project-starts-9.html |
You'd think someone could 3d print a pattern then make a plastic plug to snap in place. I'd pay for one.
I beat one into shape out of stainless sheet. It was hard work, but thats what I had available. Used silicone around the edge and screwed it down as well.
| All times are GMT -8. The time now is 01:36 AM. |
