Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
LinkBack Thread Tools Rating: Thread Rating: 7 votes, 1.57 average.
sugarwood's Avatar
Thanks for the feedback guys.
It's good to know this is not normal.
I'm going to try fanaudical's tips now.
1986 3.2 911 coupe.
Old 12-02-2017, 01:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
proporsche's Avatar
hi i do not know if you have seen my re: but have you tried it when the car just sits?Do you feel or hear any clunk?
Ivan
Old 12-02-2017, 01:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
Originally Posted by sugarwood View Post
Great memory, Bob !
Here is that thread from 2 years ago.
You know I got time for you, Bro.
1981 911SC Targa
Old 12-02-2017, 02:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
Ivan
The bolts, #8, would be frightening if loose.
Agree. Sugarwood needs to get the car on simple ramps and have a friend turn the steering wheel.
I think it will be evident.
1981 911SC Targa
Old 12-02-2017, 02:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
Bollweevil
Originally Posted by 74-911 View Post
........and to try to identify and replace only the "bad" part on a front suspension makes no sense (IMO anyway).
Dumb post on my part, didn't notice you had an '86. Kind of a no-brainer on a '74 to do a total refresh when you develop a little slop. Not so much so on a '86 however..
carry on...
Jack
74 911 Coupe
2.7L - S suspension
Old 12-02-2017, 02:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
Undocumented User
McLaren-TAG's Avatar
It should handle like this
That slop is not supposed to be there, I'd start with with the steering rack as the prime suspect.
Old 12-02-2017, 02:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
Online diagnosis for the symptoms you describe can sometimes be hit and miss or just WAGs.
Don't know your capabilities and mechanical skill level, but it's tempting to throw money at potential fixes without knowing the cause of the symptoms you're experiencing. The strategy of hit and miss diagnosis can become expensive. Don't succumb.
In that case, you can hopefully find a trusted referral to a pro tech. who can properly diagnose and ensure the basic structure/system is okay or needs repair/replacement.
In addition, try to drive an equivalent car to compare and confirm you've grown past early 911 ownership. Newer is usually better, but it isn't the same driving experience.
Sherwood
Old 12-02-2017, 02:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
sugarwood's Avatar
TAG, I have also done AX and DE in my car. Doesn't prove much.
In fact, that yank at :21 seems odd. You sure there is no slop in your car?
When you start at :35, you jerk the wheel again, and the car still appears to go straight.
I also thought my 911 was tight, until I started driving a modern car a few months ago.
1986 3.2 911 coupe.
Old 12-02-2017, 03:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #28 (permalink)
“It's good to know this is not normal.“
You could use a bit more confidence in the design-engineering of old 911s before assuming that your particular worn-out / damaged 911 is factory spec & everyone else's old 911s are like yours (& that’s been tolerated by 911 owners for a half-century).
I urge you to drive / ride-in every old 911 you possibly can. It should reduce your angst about how poorly they were engineered, how lousy they behave.
Old 12-02-2017, 03:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #29 (permalink)
Undocumented User
Drive someone else's 911. Something is wrong with YOUR car, no a well sorted 911 doesn't drive like a truck... Ferdinand is rolling over in his grave.
Old 12-02-2017, 03:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #30 (permalink)
OneMore's Avatar
Going through similar symptoms.
Thanks for your interesting feedback.
Sent from my Moto G (4) using Tapatalk
Old 12-02-2017, 03:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #31 (permalink)
devalued member
juanbenae's Avatar
the 3.2's IMO are kinda hung out between eras. they required all the amenities of a top of the line car of the day adding weight and bulkiness to achieve those goals. 1. comfort, 2. sporting in that order.
they seem to me to be heavy handed and under powered with my minimal experience driving them over the years. they are caught between the somewhat lighter SC and the greatly increase power, coil over suspension, and enhanced creature comforts of the 964 cars.
you've got all the down side of a torsion bar car without the lighter attributes of the middies & SC models that being lighter makes them fun as hell to drive. on the weekends.
75S "domino"
07.5 2500HD Diesel 4x/93 Wrangler YJ "the Barbie"
08 DRZ400SM+FCR Mikuni/82-XR80SM
03 996TT(sold 10/16 stupid&fast)78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 12-02-2017, 04:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #32 (permalink)
1980 911SC
ShoeDoc's Avatar
My E55 AMG has tight steering; as a modern car, it handles like the modern performance car it is. That said, my '80 SC handles just as well, just differently - it's like a go-cart on rails.
The SC is not tricked out - the only mod is a top mounted stabilizer... but, true confession: I went through the entire suspension system and refurbished it completely. It's almost 38 years old and I figure that my life was worth the money. I'm not the competent mechanical technician I once was and relied on a shop that is renowned for their knowledge of Porsches; it was one of the better investments I've made.
All that said, your 911 should - with proper care (and repair) - should be a delight to drive and inspire confidence.
I guess I'm just encouraging you to have a pro look it over, hope I'm not being preachy. Your life is worth every pfennig.
1980 911SC (Casablanca Beige Metallic)
2007 E350 Mercedes-Benz (Black) (SOLD)
2005 E55 AMG Wagon (Silver)
1994 Toyota Land Cruiser (Forrest Green "Rottiemobile")
Old 12-02-2017, 04:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #33 (permalink)
devalued member
juanbenae's Avatar
a quick question shugwood, have you always had a short attention span?
75S "domino"
Old 12-02-2017, 04:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #34 (permalink)
sugarwood's Avatar
Maybe you can elaborate,
1986 3.2 911 coupe.
Old 12-02-2017, 04:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #35 (permalink)
OK, I stopped after the 3rd or 4th response: If this car so upsets you, sell it. Buy yourself a Honda (or some such). I've owned my 911 SC since new, bought in 1983 and I absolutely do not have any of the issues you're reporting. If you're so enamored with a newer car, sell it, buy a newer car. There will be plenty of people who will correct whatever issue exists and treasure the car. Life's too short.
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
Old 12-02-2017, 04:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #36 (permalink)
Hope jb doesn’t mind, let me try.
In two posts, you seem to have flipped from accepting something’s wrong with your steering rack to going back to pointing out the flaws in the 911 steering as in tag’s vid. That might be puzzling to folks here.
Old 12-02-2017, 05:04 PM
  Pelican Parts Technical Article Directory    Reply With Quote #37 (permalink)
sugarwood's Avatar
It was not clear to me how a video of him driving AX proves something is wrong with my car.
Then I noted that his own steering seems to have play while stopped.
That now means I have ADD?
In any case, I took some more video of the diagnosing.
Here is a video of the smuggler's u-joint.
I do not see any obvious slippage.
I also turned the steering wheel while in Park. Keys not in car.
Can the typical steering wheel move this much while in park ?
As soon as I start turning, the tires can be seen pivoting, so it's not "free play"
Can someone post a video for comparison?
1986 3.2 911 coupe.
Old 12-02-2017, 05:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #38 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Yes the 3.2 got fat.
when I owned a '74
I test drove a SC and was Greatly Disappointed.
the weight made it a PIG compared to my '74.
Now I have a '87. It's fat, but I use it as a GT,
and for that it is well suited. For the twistys, get
a lightweight sports car and you will be happy.
Lotus Elan, any Miata, MR2 Spyder, Lotus Elise = fun
'87 911 G50 Coupe Granite Green / '90 VW Westfallia Camper
Priors: '83 911SC Cab, '67 Lotus Elan, '65 Porsche 356, '74 Porsche 911, '70 914 Porsche, '00 BMW M Coupe, '96 M Miata, '01 MR2 Spyder, LandCruiser FJ60.
Old 12-02-2017, 05:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #39 (permalink)
one of the great unwashed
patkeefe's Avatar
It did not come from the factory with play in it. Period.
Patrick E. Keefe
78 SC
92 968 Cab
01 Boxster
RIP, Early_S_Man & RoninLB
Old 12-02-2017, 05:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #40 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
