76 911 2.7 oil return lines oil direction
Hi,
I'm at the oil return lines and removed the factory leaky lines that someone tried to fix with silicone.
Obviously they are done and I have aluminum expandable lines with new oil o rings.
Is there a preffered way to install these in the engine based on the oil flow direction?
Few pics.
1974 911 coupe 4 speed
Old 12-03-2017, 03:42 PM
Expandable oil return tube orientation.......
Kava,
The smaller or inner tube goes to the cam tower and the biger tube goes to the crankcase side. Apply some o-ring lubricant like Molykoe 55 from Dow Corning for the o-rings.
Tony
Old 12-03-2017, 04:05 PM
Originally Posted by boyt911sc View Post
Kava,
The smaller or inner tube goes to the cam tower and the big tube goes to the crankcase side. Apply some o-ring lubricant like Molykoe 55 from Dow Corning for the o-rings.
Tony
Fantastic. Thank you Tony.
I have never used that grease before, I have just placed one tube on order.
Thank you.
Old 12-03-2017, 05:12 PM
