Closed Thread
LinkBack Thread Tools Rating: Thread Rating: 8 votes, 2.00 average.
What are you doing about the fact that the inlet port on the front condenser (#6 fitting) is TOO SMALL for that? Ignoring that fact?
Mike Bradshaw
1980 911SC sunroof coupe, silver/black: The Wurster
2006 Mazda3 5 door, M-speed exhaust: The Ricer
Putting the sick back into sycophant!
Old 12-20-2017, 06:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #41 (permalink)
Porsche Crest THE TAN SWAN's "Completely Modernized NEW Technology 911 A/C SYSTEM"
THE TAN SWAN Professional Install 2-11-14
PRODUCES CONSTANT ICE COLD VENT TEMPS IN THE 30's F @ 95 Degrees F Ambient
IN ALL DRIVING CONDITIONS! COMPLETED JUNE 2014
Everything in the A/C system has been re-engineered on this 911
THE AC SYSTEM has a VOV Valve instead of a TXV VALVE feeding the evaporator
REVERSING THE GASES
ALSO HAS The HIGH pressure compressor gas is routed instead of to the rear condenser inside the hot engine compartment; it is first routed/secquenced from the A/C compressor to the Front PFC, then the high pressure returns to the engine compartment partially condensed at a lower temperature and pressure DROP as both a liquid and also a gas refrigerant gas mixture; then returns/sequenced to go to the rear Deck Lid large PFC where it becomes liquid refrigerant; then it leaves the rear PFC via hose that is routed/sequenced to the inlet evaporator valve and is injected into the evaporator and then changes phase inside the evaporator as low pressure gas refrigerant and exits out of the evaporator and rerouted back to the compressor Low Pressure side to begin the A/C cycle again.
I MAKE THE MOST EFFICIENT A/C CONDENSER HEAT EXCHANGERS EVER CREATED FOR THE EARLY MODEL PORSCHE 911 WITH NEW TECHNOLOGY USING ONLY 2 PFC's INSTALLED IN THE ORIGINAL PORSCHE 911 OEM BODY CAVITY FRONT & REAR LOCATIONS
WEIGHT
5 LBS 5 OZ's Total Weight of my new version of BOTH FRONT & REAR PFC/s
Front PFC ONE pound .95 ounces
Rear PFC THREE pounds .56 ounces
My State of the Art PFC's have proven repeatedly to enable early model 911's A/C systems properly prepared to PRODUCE vent temps in the 30s @ 92-95 degrees ambient professionally installed reversing the gases!
ICECOLD911
Old 12-20-2017, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #42 (permalink)
Porsche Crest THE TAN SWAN Rear Deck Lid PFC
Rear Deck Lid PFC
Rear Deck Lid PFC MUST BE COMPLETLY SEALED TO THE DECK LID WITH NO SIDE AIR LEAKS TO TAKE FULL ADVANTAGE OF THE LARGE ENGINE SUCTION COOLING FAN AMBIENT DECK LID AIR INLET!
REAR PFC FITS THE 911 COUNTURES LIKE A GLOVE CURVED AND FLUSH TO THE DECK LID
NOTICE ABOVE THE 2 APPOX. 1 INCH SELF TAPING SHEET METAL SCREWS ONLY ARE NEED TO FASTEN THE REAR PFC TO THE DECK LID; AND THE BELOW ENGINE LIGHT BRACKET MOUNT AJUSTED IS ALL THAT IS NEEDED TO COMPLETE THE SEALED MOUNTING OF THE REAR PFC
THE SMALL RIGHT SIDE ALUMINIUM TANK IN BACK OF ENGINE COMPARTMENT YOU CAN SEE JUST ABOVE THE RED HOSE LINE IS AN A/C RECIEVER/FILTER/DRIER TANK AND IS NEEDED FOR SYSTEMS WITH VOV ORIFICE VALVES TO PREVENT LIQUID REFRIDGERENT FROM INTERING THE COMPRESSOR LOW PRESSURE SIDE RETURN FROM THE EVAPORATOR
ICECOLD911
Old 12-21-2017, 10:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #43 (permalink)
Porsche Crest Front pfc
FRONT PFC
HIGH CFM FRONT PFC BLOWER
ICECOLD911
Old 12-23-2017, 07:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #44 (permalink)
Porsche Crest Front-p-f-c
The FRONT SHROUDED PFC ROCK GUARD IS AN OEM Porsche 911 ROCK GUARD MODIFIED BY RE-BENDING and simply re-welding the outside support tabs to fit the front PFC
zxc
ICECOLD911
Old 12-24-2017, 06:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #45 (permalink)
Porsche Crest The Tan Swan DRIVING TESTS
CONSTANT ICE COLD VENT TEMPS IN THE 30's F @ 95 Degrees F Ambient WITHOUT FREEZING UP
The The Tan Swan Vent temps WOULD/CAN easily go down into the low 20's @ 95 degrees F ambient, but it was decided by the FAMILY OWNERS wanted Vent Temps kept above 38 degrees F, just to be more safe from freezing up the A/C system.
To say the least the FAMILY owners were More Then Extremely Happy with the "COMPLETELY MODERNIZED TO NEW TECHNOLOGY 911 A/C SYSTEM!"
The the 911 cabin temp would drop from over 160-180 degrees parked setting in the sun the moment the door was opened and he sat in the car and started the engine with the A/C running; it only took a few blocks and a couple of minutes driving before the cabin was ICE COLD and he had to adjust the A/C temp UP to a warmer comfortable NORMAL setting.
ICECOLD911
Old 12-24-2017, 08:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #46 (permalink)
Porsche Crest I consider TXV Thermal Expansion Valves OBSOLETE AND PREFER VOV ORIFICE VALVES!
still editing
Because my custom made 911 new technology A/C PFC's are extremely efficient, over several years engineering and testing development, I have experimented with every type of ways to control evaporators LIQUID REFRIGERANT to enhance the injection into evaporators, to control very low temperatures using a variety of injection valves.
THE MOST EFFICIENT I HAVE FOUND AND USED IS THE VOV ORIFICE TUBE BAR NONE! Today this is ALL I WILL USE IN AN EARLY MODEL 911!
The variable orifice valve (VOV) was developed to improve the performance of a standard fixed orifice tube (FOT). A variable orifice valve will significantly improve A/C system performance at idle and low speed driving, especially in high temperature climates. The variable orifice valve is a direct replacement for the original fixed orifice tube. No physical modification is required to upgrade the A/C system.
Improves system performance in hot idle situations
Delivers five to twelve degree colder vent temperatures
Improves city driving fuel economy and emissions
Reduces compressor load to help extend compressor life
THIS IS ALL THAT IS NEEDED IN A 911 TO CONVERT TXV VALVES TO VOV VALVES
PLUS A SMALL RECEIVER/DRYER PROTECTION TANK THAT PREVENTS LIQUID REFRIGERANT FROM ENTERING THE A/C COMPRESSOR
I.E. SOMETHING LIKE THIS TANK on the far right side in back of the engine compartment
ICECOLD911
Old 12-25-2017, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #47 (permalink)
Porsche Crest
I made a new post in this Thread about another NEW FenderWell PFC I want to start making but just deleted what I said about it here and created its own Tread so it does not take away or interfere with the purpose of this Thread
If you want you can see it http://forums.pelicanparts.com/porsche-911-technical-forum/982154-i-have-had-new-911-dual-pfc-fenderwell-condenser-0n-my-mind-several-years.html
ICECOLD911
Old 12-28-2017, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #48 (permalink)
Happy New Year
ICECOLD911
Old 12-30-2017, 08:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #49 (permalink)
S0UTH FLORIDA 911 A/C TESTERS FYI MY New Front PFC DESIGN WILL BE A DUAL PFC,
with State of the Art Micro-Channel
ICECOLD911
Old 01-04-2018, 05:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #50 (permalink)
For 930 owners I have a different NEW Dual Fenderwell prototype PFC you may be interested in, I just made and announced in a new tread today
Could This PFC BE The Holy Grail For Early Model 911 A/C System
ICECOLD911
Old 01-13-2018, 06:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #51 (permalink)
Porsche Crest New Fender Well DUAL PFC Testers Wanted
I have been custom making MICRO-CHANNEL PFC's for early model 911's for over 8 years!
THIS New DUAL PFC is very near being completed, it only needs a CUSTOM shroud and hose fittings added in the next few days to be done.
IT IS UNTESTED!
I made 2 of these, one for testing and one for marketing, etc
I want to finally be the first to make The Holy Grail For Early Model 911 A/C System, USING Only One Dual PFC Condenser to run the whole 911 A/C SYSTEM
The 911 DIY Tester will only need to basically disconnect their current A/C Condensers hoses, (but leave them in place). get a couple of very short reduced barrier hoses and hook them up to the new Dual PFC Fender Well you will install into your drivers side wheel well and to a new filter dryer and then to your evaporator. Recharge your A/C SYSTEM with probably less then A Pound of R134A
FOR THIS TEST you can be anywhere in Florida or maybe even in another USA State?
If you are seriously interested send me a private message here.
I want someone who has a fully working A/C SYSTEM, I WANT SOMEONE THAT CAN DO THE INSTALL FAIRLY QUICKLY. AND REALLY WANTS TO BE A PART OF MAKING EARLY MODEL 911 HISTORY!!!
I know this DUAL PFC has the needed A/C condenser surface area to run the whole 911 A/C System!
The blower on it I have chosen is 950 CFM of air cooling
I will need a $450 deposit security on the PFC; I will make the PFC DEPOSIT fully refundable if its sent back to me completely undamaged
If you want to be a part of making 911 history let me know!
Still editing this
ICECOLD911
Old 02-04-2018, 09:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #52 (permalink)
Porsche Crest Total Weight Fender Well DUAL PFC & Blower Fan 6.5 Pounds
LESS SHROUD & HOSE FITTINGS
ICECOLD911
Old 02-04-2018, 01:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #53 (permalink)
Porsche Crest This New Dual PFC has the Surface Area Capacity ALONE TO RUN THE WHOLE 911 A/C SYSTEM
This New FENDER WELL Dual PFC has the Surface Area Capacity ALONE TO RUN THE WHOLE EARLY MODEL 911 A/C SYSTEM
OR IT CAN BE USED TO SUPPLEMENT YOUR OTHER HEAT EXCHANGER CONDENSERS
IT IS ALMOST COMPLETED EXCEPT FOR THE SHROUD AND HOSE FITTINGS
I BOUGHT THE METAL TO FABRICATE THE SHROUD TODAY and already have the fittings
IT IS UNTESTED
IT HAS THE SAME CAPACITY AND SURFACE AREA AS 2018 NEW PORSCHE 911 A/C SYSTEM HAS AND PRODUCE SIMILAR ICE COLD VENT TEMPS @ 95 DEGREE'S F AMBIENT
IF YOU WANT TO BE A PART OF MAKING 911 HISTORY and your serious PRIVATE Message me
Its not free
ICECOLD911
Old 02-07-2018, 06:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #54 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
No one cares. You got nuttin' but wind.
Same story since 2011. Really?
Oh yeah. I need a life, right? Keep going and get this thread closed as well.
You are the quintessential engineer. Gimme some archimedes in a bathtub crap.
Put up or shut up. I dare you.
I liken you to Richard Simmons. How different is that from calling someone an idiot?
Name calling. Your downfall.
1981 911SC Targa
Old 02-07-2018, 06:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #55 (permalink)
The Put UP or Shut UP IS RIGHT HERE BEFORE YOUR EYES in the picture
I AM putting the hose fittings on the this Fender Well PFC TODAY, had the aluminum for the shroud cut yesterday, and going forward to finish my new micro-channel PFC creation within days,
ICECOLD911
Old 02-08-2018, 05:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #56 (permalink)
Porsche Crest
If your seriously interested in testing this new PFC condenser and being a part of Making History of the Early Model 911 and Being the First 911 OWNER To Use 0nly A SINGLE PFC Condenser to Run your Whole A/C SYSTEM In The World
You can call me @ REID KELLY 954-599-5235 in Fort Lauderdale, FL or message me here or email me captainengineer@earthlink.net and send me information about you and your 911 and why I Should pick you
You must BE IN THE USA, have a fully functioning A/C System and GOOD CONDITION 911 that is FULLY drivable
Your mechanical and A/C abilities if DIY and/or info about your mechanic
You must be willing to sign a nondisclosure agreement, I do not want my PFC engineering design stolen
Pay a $499 fully refundable deposit if you decide to return it within 30 days (if there is absolutely no damage OF ANY KIND to the PFC or Blower). or you can keep it for your 911 A/C System with a limited 2 year warranty
You must also agree to your 911 install pictures being used for publication with all types of media, and
marketing. AND to to our host Pelican Parts
ICECOLD911
Old 02-08-2018, 06:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #57 (permalink)
It about time.........
I AM putting the hose fittings on the this Fender Well PFC TODAY, had the aluminum for the shroud was cut yesterday and going forward to finish my new micro-channel PFC creation
Reid,
It is about time you do something to demonstrate your work. It has been so many years since you started bragging about your incredible discovery. My youngest grandchild was not yet conceived when you proclaimed to the world the holy grail of automotive air conditioning. She is already attending school and you are still looking for some DIYer to do the testing for you?
The product has not undergone extensive testing and yet you claimed it to be the best discovery since slice bread. This is a Technical Forum and will need concrete evidence of your work. Do you have anyone living and not imaginary to back up your incredible work? Or you are still editing? Keep us posted or shut up.
Tony
Old 02-08-2018, 06:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #58 (permalink)
What happened to the cardboard box?
JUAN
'80SC Targa
Old 02-08-2018, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #59 (permalink)
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
It's on display at the Guggenheim Museum.
Old 02-08-2018, 07:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #60 (permalink)
Closed Thread
