FYI old bmw /5 airhead motorcycles use the same retaining clips if you need to find them from another source.
1979 SC
1986 Carrera 3.6 L+
Old 04-12-2018, 06:40 AM
3Ddesigns911's Avatar
Thanks for the info on the clips.
Unfortunately my H5 ring screws were missing to begin with, so I still need to figure them out.
Sent from my SM-N900V using Tapatalk
zK
3D Designs
87 911 Carrera targa RestoMod
Instagram#3DdesignsSD
Old 04-12-2018, 06:44 AM
I make the headlight attachment screw. Currently I'm down to my last few of them made from brass and then chrome plated (like oem). I've got a stainless version in production and they will be much cheaper than the current price on the last few of the brass based ones, probably about $8 each for the stainless including the nylon washer and black rubber buffer.
tks,
Eric
Accessory Parts
http://www.autoforeignservices.com/
57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc.
Old 04-14-2018, 07:48 PM
tks,
Eric
Accessory Parts
Thanks Erik, I ended up getting 5mm stainless screws. I'll let you know if they don't work.
zK
3D Designs
Old 04-14-2018, 10:00 PM
I learned that not all clips are created equally.
I originally had some from Germany that I ordered with some parts, but I did not order enough. Long story short I got some extra ones, and to my surprised they are much bigger and work so much better than the other ones I had bought earlier. I think the big ones might be for VW and the small ones for Porsche, but maybe because I am using VW lenses with H4 rings they just work better.
Check it out.
Here they are installed. I mixed them up. Some places the small ones actually work better.
Looks like I have the lens a bit off centered. I never even noticed it until now.
and voila I have LED lights with VW lenses in H4 rings over sugar scoop buckets mounted on H5 mounting base.
zK
3D Designs
Old 04-19-2018, 08:12 PM
web geek
emptyo's Avatar
Send a message via AIM to emptyo Send a message via Yahoo to emptyo
Those look really clean. Nice work.
Michael O'Neal -
69 RSR Clone(ish) - Read about the build: http://bit.ly/69porschersr
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-20-2018, 12:33 AM
Carmagic.us
rothaus's Avatar
Looks good. How is the light pattern of the LED inserts ?
When I tested several inserts, I had a similar set and they made 3 spots on low beam.
You can see it in the picture below, also in the reflection on the hood.
The ones I use now have a nice cutoff with the 2low beam projectors, shown below.
Here installed.
For BA7s Dash LED, External Marker LED, and LED headlights go to https://carmagic.us
Old 04-20-2018, 05:18 AM
Not sure about the pattern, but it doesn't appear to have 3 hot spots. I have no seats in the car to drive at the moment, but the beauty of this setup is that it's super easy to swap in any 7" light if one doesn't like them... conventional H4 or other LED.
zK
3D Designs
Old 04-20-2018, 11:52 PM
You were right about the lights.
I did end up using an insert like yours, and they do have an awesome output. Yesterday on the way home on the freeway my lights were brighter then most other cars around me including the ones that were lit up like a Christmas tree.
Thanks for the tip!
zK
3D Designs
Old 06-13-2018, 06:19 PM
