3Ddesigns911's Avatar
I am making H5 to LED headlight conversions
I know this has been done already. I have searched what my options are, and decided to make my own H5 to LED headlight retrofit.
For the LED-s I have also been researching my choices and decided to go with the Nolden second generation bi-LED headlights.
Basically, this is what I am going to build.
https://en.noldengmbh.de/en/products/tuner-eng/44-unternehmen/tuning-news-eng/131-rpm-ncc-bi-led-hauptscheinwerfer-fuer-porsche-eng
I have already sourced the lights and imported the proper Porsche buckets, (so I don't have a small light bulb socket on the bottom) from Germany.
I thought since i am building one set I could build two if anybody is interested.
Let me guys know what you think.
zK
3D Designs
87 911 Carrera targa RestoMod
Instagram#3DdesignsSD
Old 12-03-2017, 09:25 PM
Lund's Avatar
i'd be interested in a set
Old 12-03-2017, 11:28 PM
I'm interested too. Thanks.
Old 12-04-2017, 12:38 AM
Hi,
Very interesting!
Difficult to have information in France by going on your link, do you know the price of these lighthouses?
Old 12-04-2017, 01:33 AM
Carmagic.us
rothaus's Avatar
They Look great. Almost like mine.
Cheers
Engelbert
For BA7s Dash LED, External Marker LED, and LED headlights go to https://carmagic.us
Old 12-04-2017, 04:42 AM
Bill Verburg's Avatar
Cheers
Engelbert
What's the current draw vs std 55/55 H4s
Bill Verburg
Old 12-04-2017, 05:07 AM
please share how you build them. I already have the clear lenses but don't know yet exactly how to mount the GL-180 headlights
Old 12-04-2017, 05:19 AM
Hello,
Long Time lurker from Oz.
Here are ones I made with Jeep LED'S 55 Watt (5 Amps) <$200 Australian including LED's, VW round inserts and clear glass.
Very easy, cheap and a huge improvement.
Old 12-04-2017, 05:28 AM
Carmagic.us
rothaus's Avatar
These are 30W low beam, 48W high beam. The low beam stays on during high beam. They also have DRL/parking light function if needed.
Cheers
Engelbert
Old 12-04-2017, 05:39 AM
I will be combining the back section of the H5 retaining bracket with the headlight holding section of the sugar scoops, essentially that is what holding the LED lights in place. Then we need to fabricate the parts to hold the bucket/lens/ring assembly.
I don't have all the pricing yet, and since the sugar scoop parts are going to be used (most likely) it will also depend on their cost, so that's a variable number.
FYI, I am not making this to be a cheap replacement. That's why I selected the Nolden, which is a premium light using OSRAM chips, comparable to the JW Speaker but more economical. I am also getting the buckets from Germany that does not have the small light bulb socket on the bottom. IMO the devil is in the details and since I'll be using clear lenses you can see what's behind it. Maybe the lenses are something to save some money on, I did find a set of clear Hella lenses for myself, but i think could go with the cheaper non-branded versions as well.
Anyway, I just wanted to though it out and see if I am making more than just my own set I could just as easily make another one or two the same time.
Let me know who's in and I'll keep you posted on my progress also.
zK
3D Designs
Old 12-04-2017, 09:36 AM
froggert's Avatar
Why use the H5 piece if you already have a headlight bucket?
Old 12-04-2017, 09:55 AM
Such that he can use the H5's more secure mounting system a la what @Cook&Dunning did here... H5 and sealed beam headlight conversion
Frank Amoroso
1987 911 M491 Coupe
1988 911 M491 / M470 Cabrio
WTB / ISO: G50 911 M491 Coupe or Targa
Old 12-05-2017, 11:52 AM
Exactly.
Sent from my SM-N900V using Tapatalk
zK
3D Designs
Old 12-05-2017, 11:56 AM
froggert's Avatar
Oh, I see now. Thanks for the link. That mounting and aiming should be much more secure and stable than the usual H4 method. Wish I'd seen that before converting my headlights.
Old 12-05-2017, 12:27 PM
newbie
i too would be interested in a set, i have the H$ setup now with Euro glass but to be honest prefer the combined scoop clear look
Bob
Old 12-05-2017, 01:39 PM
needspeed's Avatar
Has anyone tried H5 LED bulbs as a plug-n-play replacement?
Old 12-30-2017, 05:26 PM
Typically brighter bulbs don't make bad lights any better. They only make brighter light scatter all over the place.
The H4 design and good LED lights have much better patterns and sharper cut off. There is really no contest.
zK
3D Designs
Old 12-30-2017, 05:34 PM
newbie
Light Set
PM sent
Old 12-31-2017, 07:53 AM
I finally started working on my lights and realized I don't have enough of the ring retaining clips (springs), as well as the screws for the bottom of the rings.
I have a couple of questions also.
  • Are there specific locations around the ring where these clips have to go? How many do I need?
  • Also is the screw a specific one? i am seeing a couple of different versions, one with a plastic sleeve and one with just a longer neck.
This is what I have so far
Sorry about the bad pix, it was getting dark
LED light in a hybrid H5/Sugar scoop bucket.
Light on low beam
The ring assembly is just hung on the car here. It's not actually screwed on yet.
zK
3D Designs
Old 04-11-2018, 10:20 PM
Carmagic.us
rothaus's Avatar
You need 8 clips, one on top, one at the bottom, and 3 left and right.
You should be able to use the same bottom screw you had in before.
Also, don't forget the rubber seal between the outer ring and the glass.
Cheers
Engelbert
Old 04-12-2018, 04:42 AM
