mskala's Avatar
leakdown air from between cyl and head
I'm confused. Backstory will be farther down, but I did a leakdown and only
#6 cylinder was about 45%. No air from intake or exhaust but definitely under
the car. After engine is out (2.2 but with JE pistons, AA 86mm Biral cylinders) I
find no broken rings or scored cylinder. Re-bolt down heads and put leakdown
tester back on, and the air is coming from the bottom side of where the head
and cylinder meet.
I had cleaned the mating surface of the heads, there doesn't seem to be any
damage and these were done by a reputable shop only a few thousand miles
ago.
Right before this happened, I was doing an autocross and lost the fuel pump
(carbs) during a run, so for 30 seconds or so it was acting weird, likely getting
leaner and leaner while I'm still going full throttle. After fixing electrical issue
with fuel pump, I did a bunch more runs but seemed to be running a bit poorly
going home.
Not sure where to go next to isolate why the head is not mating up properly
any more, or if i'm doing something wrong.
Mark S.
'70 914-6
Old 09-29-2017, 08:24 PM
I would rather be driving
jpnovak's Avatar
few Thousand miles?
Check head stud torque. Could be loose or pulled stud from 2.2 Mg case.
Old 09-30-2017, 06:05 AM
mskala's Avatar
There didn't seem to be any loose nuts when disassembling. I've temporarily
re-installed on the bench and torqued to 20. The studs are still all the same
length so not pulled. I put this together, heads were newly done, last year. Now
has 8K miles on it. Very strange.
Mark S.
'70 914-6
Old 09-30-2017, 07:23 AM
Did your shop resurface the heads when they were rebuilt?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-30-2017, 11:33 AM
mskala's Avatar
Yes, they were resurfaced.
It's hard to see but this is my pic of mainly #6. I used carb cleaner on the mating
surface and it seems normal I can still see the machining marks all the way around.
Mark S.
'70 914-6
Old 09-30-2017, 12:05 PM
mskala's Avatar
Well just trying things, and I swapped cylinder and piston #6 with #5. Now, the
leak is in #5, and #6 doesn't leak. So I think that eliminates the heads and points
to something about the one cylinder. Of course I also just realized that I was test
assembling with the old kinda beat up copper base rings, and just for diagnosis I
can try putting it together without any base rings and try again.
Mark S.
'70 914-6
Old 09-30-2017, 06:01 PM
Suspect, then measure cylinder height. You seemed to isolate this when you swapped cylinder positions (6>5) and observed the same symptom.
Sherwood
Old 10-01-2017, 09:56 AM
kwikt 911's Avatar
Was your head gasket crumbled when disassembled?
Old 12-09-2017, 06:06 PM
Home of the Whopper
I had air leaking there also on a 3.0.
I was able to lap the head and cylinder and issue went away.
Good luck!!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 12-09-2017, 06:22 PM
