jblair
90 degree Swivel nut fuel line fitting
Hello looking for a 90 swivel nut M10x1.0 used on a bosch ke jet system it connects the 6mmOD x 4mm ID polyamide choline line on a Ferrari testarossa fuel pressure regulator to the distributor. Not sure if porsche used such a fitting but thought someone here might be able to chime in
Recently Disbanded
try summit or the like for a universal fitting that may suit your needs unless originality is a factor. it won't look like that but I suspect there is something suitable.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Like the one on the bottom of the fuel accumulator on an SC.
Bruce |
90° angle fuel line fitting........
Bruce, That was exactly what I thought too. But the 90° fitting for the fuel accumulator is 14-mm x 1.5 much bigger than 10-mm x 1.0 that he needs. ![]() These are the fuel return line fittings from the fuel accumulators which are 14-mm x 1.5. Tony Last edited by boyt911sc; 12-04-2017 at 04:02 PM.. |
Belmetric lists them with a Bigger thread than what you are looking for but I bet they could source it for you
jblair
Hey guys I have checked with Belmetric and the only thing available is that M14x1.5 90 fitting. I did find an ebay add for a fitting but the seller could not confirm the size, i've attached a link if anyone want to chime in, they say its for a 74 911. Might have to bite the bullet and purchased a used line for $100 just to get the $10 fitting
Jgm,
The picture you posted was taken from the eBay posting which came from a fuel accumulator. I will bet that it is a 14-mm x 1.5 pitch. Do you have a picture of your fuel distributor showing the fuel line connectors? Thanks. Tony |
jblair
Here you go! This is the fuel pressure regulator on the 1-6 bank of a 12 cyl testarossa. The PITA with this fitting is it has to be 90 degrees on this side to clear the throttle body in order to get back to the fuel distributor. The other side is no problem as it is just a straight swivel nut and readily available from numerous sources. As I stated in my previous thread it is an M10x1.0 fitting and the barb needs to fit a 4mm ID polyamide hose.
Cheers, Jeff
