Sunroof rear height adjust
Yes, again! The car is a 78 930
I have read probably 10-12 threads on this. Still issues. Sunroof opens and closes well. New cables and seals installed. The problem is the rear height is about 3/8” from closing. Adjusted the serrated lift points countless times - no remedy.
It acts as if the sunroof needs to go forward more to get the wedge shaped plastic runners to strike the plastic domed piece to raise up completely. But it is as forward as much as it can be.
One suggestion was to actually lower the pivot post to allow a shallower angle so that it may raise easier. Well, no that didn’t work either. I raised those adjustments to full height and minimum height adjustments. No difference.
So any suggestions other that a heavy hammer adjustment would help tremendously.
Thanks all
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 02-20-2022, 02:56 PM
Sunroof delete panel
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-20-2022, 03:10 PM
New updated side cable guides as well? They work with the new style cable as I understand.
Formerly owned 70 911S, 73 911S. Wish I had pickled them! had a 75 930 #17. now in museum in Canada. 81 930 , 84 911 Cpe. 74 Carrera cpe. , 72 BMW 3.0 cs, 91 M3, memory foggy on some of the rest. Current toy car 86 911 cpe.
Old 02-21-2022, 06:35 AM
Yes new cables and seals.
The pivot hardware acts as a limiter for height adjustment. The rear of the sunroof lifts up when the wedge shaped plastic attachments hit the plastic domed cap which protrudes thru the rails. I may have to figure a way to raise those up a bit - but it originally is not designed that way. So I will remove the sunroof - AGAIN - for the 20th time and try some new adjustments.
Right now - sunroof delete sounds great
Old 02-21-2022, 06:45 AM
has anyone inserted shims on the plastic wedge guides so that it creates a larger gap between the guide and the bottom skin of the sunroof. In turn, that would raise the rear of the sunroof that shim thickness?
Old 02-21-2022, 05:16 PM
Designer King
Paulporsche's Avatar
mrm930,
I have. I used washers and increased the length of the bolts to accommodate. Works just fine. BTW when you reattach those clips make sure the travelling part is as far forward as it can go and still be able to reattach to the panel. This way you get as much height and forward force as possible.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-23-2022, 09:43 AM
