Fuse question
I went to replace my fuse for glove box, interior lights, and clock which according to the manual requires a 5 amp fuse. The blown white fuse is 8 amp. If I replace it with 8 amp should that matter or should I get a5 amp fuse?
Hi Rx,
It depends why the fuse blew. If every connection and component is perfect, then the difference between 5 and 8 amps might not matter. Might as well put in the correct one though. Good luck, Dave |
Thanks Dave. I accidentally caused a spark trying to fix my glove box light and blew my fuse, which was diagnosed by fellow pelican yesterday. Just having a hard time finding 5 amp fuse. Plenty of 8 amps around.
I would buy 1 or 2 5 amp fuses if it were me. My 2 cents.
Was a bit hard to find the 5 amp, but napa does carry them online. Will do just that.
Pack of 40 (10 of 5A, 8A, 16A and 25A for $12 with free delivery.
https://www.amazon.com/40-piece-Ceramic-Torpedo-Mercedes-Porsche/dp/B00KQHJDB4/ref=sr_1_1?ie=UTF8&qid=1513071902&sr=8-1&keywords=porsche+fuse |
Thank you JJ.
Just checked and they not available
few options -- https://www.amazon.com/Bullet-Ceramic-Torpedo-Flosser-Germany/dp/B00KO9F2IM/ref=pd_sim_263_3?_encoding=UTF8&pd_rd_i=B00KO9F2IM &pd_rd_r=BG8ZBKG36W0XD893R7XN&pd_rd_w=w9nms&pd_rd_ wg=VzNDx&psc=1&refRID=BG8ZBKG36W0XD893R7XN == 5 pack
or, if you NEVER want to be lacking a 5amp fuse again -- https://www.amazon.com/Bullet-Ceramic-Torpedo-Porsche-Mercedes/dp/B06WP38MT4/ref=pd_sbs_263_3?_encoding=UTF8&pd_rd_i=B06VTH6TS5 &pd_rd_r=BG0CJ3S6T5V3AMYX2VP7&pd_rd_w=zsNC1&pd_rd_ wg=7RyXR&refRID=BG0CJ3S6T5V3AMYX2VP7&th=1 |
| All times are GMT -8. The time now is 05:27 AM. |
