-   -   911 SC - Mystery dash switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/981503-911-sc-mystery-dash-switch.html)
Kftca 12-22-2017 05:28 AM
Hi Folks:
I am a 911 newbie, got my 1st Porsche ever, last summer, a 78 911 SC Japanese spec car, and I am really pleased with it. I would also like to say THANKS to our host and all the posters here... I have used this forum extensively already to solve all kinds of issues... fantastic.
A question: I have a switch opening in the dash between the fresh air controls and the steering column. The hole in the dash looks very stock but the PO had used this space to mount an aftermarket toggle switch to control the power antenna. The question: Is this hole a stock opening? And if so, what was the intended use of this switch?
Karl (78 911 SC coupe)
http://forums.pelicanparts.com/uploa...1513949284.jpg
http://forums.pelicanparts.com/uploa...1513949302.jpg
Flat6pac 12-22-2017 05:30 AM
There is a detent there but not drilled.
Bruce
boyt911sc 12-22-2017 06:29 AM
Welcome to the forum............
Karl,
I have attached pictures of dash sections from a 78 SC and ‘89 cabriolet. The ‘78 has indention marks (no plug) while the ‘89 has a plug with vents (?). Add you location and you might have someone near your location. Like to see picture of your engine. Thanks.
Picture from ‘89 Carrera 3.2:
http://forums.pelicanparts.com/uploa...1513952691.jpg
Picture from ‘78 SC:
Tony
tshebib 12-22-2017 06:52 AM
That is the location for an optional fader adjustment knob for your stereo.
I actually had the fader knob in that location. When I removed my center console, I moved the AC fan controller into that location. I have an aftermarket stereo so the fader control wasn't being used anymore.
Look at the pic from post #132 in this link.
http://forums.pelicanparts.com/porsche-911-technical-forum/645203-finally-registered-pelican-introduction-7.html
76FJ55 12-22-2017 07:36 AM
Originally Posted by boyt911sc (Post 9857876)
Karl,
Tony
For your information the "vent" is the interior temp sensor for your auto heat.
Kftca 12-22-2017 01:41 PM
All- thanks,very helpful. I just changed the stereo to a used Alpine cassette deck and have wired the power antenna directly to the radio ,so I have a spare slot which I will have to think of a use for!
Also noted the helpful comment on suggesting my location. I am in Dartmouth, Nova Scotia, looking forward to meeting some fellow 911 owners in the area .
Karl 78 911 sc
Dartmouth ns
tshebib 12-23-2017 02:05 PM
Karl 78 911 sc
Dartmouth ns
Wow, I din't notice your location.
Nice looking car, but then again I'm biased ;).
PCA is very active here. We meet the second Tuesday of each month at the Porsche Dealer.
Acadia Region PCA
fanaudical 12-23-2017 05:02 PM
On my '75, that is the location for the intermittent wiper timing control knob.
dyusem 12-24-2017 08:14 AM
Yup nothing but prep for the fader in my NA '80.
I believe that the intermittent wiper timing control knob in the SC was just NE of there between the speedo & clock...some good info (& laughs) posted here.
Bill Verburg posted the following image...the fader cutout seems unlisted/difficult to see in this diagram...
http://forums.pelicanparts.com/uploa...1514131836.jpg
1100sport 12-24-2017 10:02 AM
For MY 74 and 75, that location was used for the intermittent wiper switch. Starting 76, that switch moved between the gauges (the small rotating knob) and the freed location was used for other purposes like fader knob.
frankc 12-24-2017 10:20 PM
For cars with the optional Webasto gas heater, that position was used for a push/pull switch to turn the heater off/on.
hotaru 12-25-2017 03:27 PM
on my 1983 it is an antenna switch, you can lower/raise antenna.
http://forums.pelicanparts.com/uploa...1514244339.JPG
theiceman 04-24-2024 01:52 PM
here is mine
https://i.imgur.com/FTXmV1N.jpg
push pull switch . was disconnected when i got the car .. so ive had it connected to a few different things across the decades. I used to have it connected to my radar detector power so i could kill the power quickly if i needed to .
After i grew up and realized i wasn't going to be speeding around town i had a change of heart. i ditched the detector and I connected it to the electric antenna in the days before it went down when you changed the source. I could lower it when listening to a tape , then CD.
The later units were smarter and lowered the antena when you change the source to anything but radio so i no longer need it. But it sits there quietly waiting for the next application i can think of.
