-   -   reinforced shock towers (http://forums.pelicanparts.com/porsche-911-technical-forum/981917-reinforced-shock-towers.html)
rrcrawford70s 12-26-2017 01:14 PM
On a 1970 911, if you remove the torsion bars and replace with reverse coil overs and monoball suspension in the rear, how mandatory is reinforcing the shock towers?
Noticeable handling difference, lose rigidity to the shell?
Drivers Education on the track, 2-3 days per year. Street drives the other 99%
JSA993 12-26-2017 02:06 PM
I think it is very critical. There are several threads about it through the years. The rear weight of the car ends of being at two point not originally designed for this amount of weight. Some work prior will most likely save a engine/trans drop and major repairs in the future....and that could be the best outcome. Would hate to have a major failure while driving. Here is what I did on my '70 and I'm probably going to do a little more before it goes to paint......http://forums.pelicanparts.com/uploa...1514329446.jpg
Tom '74 911 12-26-2017 02:45 PM
As JSA mentioned, lots of threads on this here with opinions ranging from, "I've run rear coilovers for 20 years with zero reinforcing and it's been fine" all the way to "running rear coilovers requires a full roll cage tied to the front and rear shock mounts to support the chassis so it doesn't twist and bend where it wasn't designed to do so".
Both sides of the opinion spectrum are fully represented, although the photo that JSA posted seems to be a pretty universally accepted "must do minimum" for rear coilovers.
Steve@Rennsport 12-27-2017 08:27 AM
If you replace the torsion bars with coil springs, you'll need a complete cage that connects and triangulates all of the suspension pickup points, otherwise you get a flexy flyer and an unresponsive car.
The main reason to use coilovers on a 911 is when you cannot get high enough spring rates with torsion bars.
3literpwr 12-27-2017 09:35 AM
Getting proper droop travel on a rally car also calls for coils. Stiff indexed t-bars on cars seem to have a huge impact on one of the most importing things on gravel, droop. Also, I'd love to see someone instrument a car with String pots and the like to actually validate Steve's hypothesis.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
