reinforced shock towers
On a 1970 911, if you remove the torsion bars and replace with reverse coil overs and monoball suspension in the rear, how mandatory is reinforcing the shock towers?
Noticeable handling difference, lose rigidity to the shell?
Drivers Education on the track, 2-3 days per year. Street drives the other 99%
Ray Crawford
1972 911 S Targa
1970 911 S Coupe Flairs n Chairs
Old 12-26-2017, 02:14 PM
I think it is very critical. There are several threads about it through the years. The rear weight of the car ends of being at two point not originally designed for this amount of weight. Some work prior will most likely save a engine/trans drop and major repairs in the future....and that could be the best outcome. Would hate to have a major failure while driving. Here is what I did on my '70 and I'm probably going to do a little more before it goes to paint......
'70 T/ST Tribute- 3.6/G50 "Under Construction"
'98 C2S, '95 Carrera, '90 Carrera 2, '87 Carrera - all sold but I still have pics!
Old 12-26-2017, 03:06 PM
Tom '74 911's Avatar
As JSA mentioned, lots of threads on this here with opinions ranging from, "I've run rear coilovers for 20 years with zero reinforcing and it's been fine" all the way to "running rear coilovers requires a full roll cage tied to the front and rear shock mounts to support the chassis so it doesn't twist and bend where it wasn't designed to do so".
Both sides of the opinion spectrum are fully represented, although the photo that JSA posted seems to be a pretty universally accepted "must do minimum" for rear coilovers.
'74 911 Red Sunroof Coupe, 3.6L, etc...
Old 12-26-2017, 03:45 PM
If you replace the torsion bars with coil springs, you'll need a complete cage that connects and triangulates all of the suspension pickup points, otherwise you get a flexy flyer and an unresponsive car.
The main reason to use coilovers on a 911 is when you cannot get high enough spring rates with torsion bars.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-27-2017, 09:27 AM
Getting proper droop travel on a rally car also calls for coils. Stiff indexed t-bars on cars seem to have a huge impact on one of the most importing things on gravel, droop. Also, I'd love to see someone instrument a car with String pots and the like to actually validate Steve's hypothesis.
Old 12-27-2017, 10:35 AM
