Did these cars have an oil level indication?
Bruce |
Yes
Good luck, David Duffield
have owned/driven more than one Porsche |
Are you asking about the one on your dashboard? I think some do and some don't. In my '73 manual it shows that there is for some E's and T's
I think all S's had the oil level indicater. Don't go by the oil level indicater, it's not very accurate. Use the dipstick on level ground, on a warm idling engine.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
I agree with Tim that the oil level indicator is not the first choice for determining when you need oil. However, once you figure out where the guage rests when you have the correct level in your car, it is a good substitute for the dipstick.
Rich Mason 87 951 for sale $5500 |
i have a t with a s instrument/trim option. might have been an option on t's.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Thanks guys. I ask because I was looking at a parts diagram for the 72 and I didn't see a level sender as part of the diagram. I'm doing a project where I think the 72 oil tank will work well but I want the level, only because I want the gauge to work. As you pointed out I won't rely on it but I do want it functional.
Bruce |
Tryan nailed it...the optional on all models "S" gauge package contains the oil level gauge. Pretty well useless unless you read it under the same conditions you need to check with the dipstick. That is, car sitting level, temp above 180 degrees, engine revs at idle. For your project, it would be easiest to get the oil tank from a car that had the "S" gauges...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
