Turn Signals
Working on wiring for the EFI install, and I got sidetracked with some new relays, which led to looking at the fuse box, which led to removing some wiring for stuff I don't have (like the headlamp washers, windshield washer pump). So, I put the flasher back in to test it, and the left side blinks as it should, and the right side only buzzes at the flasher...no lights. Open circuit on the right side somewhere? My flasher does not have the C (common) pin.
| All times are GMT -8. The time now is 05:25 PM. |
