-   -   Correct part number for 3.2 throttle bellcrank (http://forums.pelicanparts.com/porsche-911-technical-forum/982097-correct-part-number-3-2-throttle-bellcrank.html)
speedo 12-28-2017 08:35 AM
Pet says this # 911.110.091.07
I have this...
http://forums.pelicanparts.com/uploa...1514482421.JPG
http://forums.pelicanparts.com/uploa...1514482431.jpg
Does the bellcrank change between CIS and DME transition?
Speedo
Matt Monson 12-28-2017 08:58 AM
Casting number versus part number. That's the correct part for the 3.2 with DME. CIS cars don't have it.
Harpo 12-28-2017 10:12 AM
I'm confused why the casting # would not be the same as the part#
Flat6pac 12-28-2017 03:01 PM
The biggest difference over the years was going from nylon bushings to brass and extending the spacer to the casting on the rear stud in the mid 80s.
Bruce
DRACO A5OG 12-28-2017 05:04 PM
Actually those bushings on that component is quite different in that it has a teflon like coating and is steel. It even comes in a vacuum sealed packaging.
