-   -   Drop links (http://forums.pelicanparts.com/porsche-911-technical-forum/982437-drop-links.html)
Bdeluca 12-31-2017 06:18 AM
Drop links
I have a 72 911 and need to replace the rear rattling drop links. I can't seem to find the correct part , I assume the rear sway bar was an after market addition. I find similar drop links but this one seems to be a little different . The lower bracket that attaches to the sway bar has a collar and I don't think I can get a bushing in there. They don't seem to be sold together ? But I don't think I can get them apart.http://forums.pelicanparts.com/uploa...1514729868.jpg
djpateman 12-31-2017 08:08 PM
Those are Heim joints. They are essentially a ball in socket design. When they get loose the only option is to replace them.
Mahler9th 01-01-2018 11:24 AM
A few more pictures from different angles might be helpful. Kind of looks like a Weltmeister set up.
See for example:
https://www.pelicanparts.com/More_Info/SB3000.htm?pn=SB-3000&gclid=EAIaIQobChMInfzV5L232AIVgTuBCh0gUQhhEAQ YASABEgIS2PD_BwE
or
http://www.weltmeister.com/ProductDetails3abc.html?productID=358
