1977 2.7 911 vacuum advance question
I am still having trouble getting the CIS adjusted properly but on the other hand I just found that the hose to the vacuum advance on the distributor is connected but there is a rubber plug somebody put in it. I took the plug out of the line and pushed it back on to the vacuum advance and it makes no difference. I just bought the car 3 months ago. It was running absolutely great until the weather turned cold at which time I set about adjusting the fuel mixture with the 3mm wrench. The aux air reg. had also seized up so I sprayed WD40 into it, reinstalled the hose and went about adjusting the fuel. I've gone richer and leaner both but it still cuts out when I get on it. I know...I'm trying to explain 2 different things here. Just don't know what to do next. It was running stellar just before the cold set in and the AAR seized up.
Old 12-31-2017, 02:02 PM
Ampex,
The vacuum line will slightly change the timing at idle, but you may not notice it.
The mixture screw is very sensitive - you don't have to move it much. How far have you turned this screw?
Do you have fuel pressure gauges? If not, they are a good investment and will be necessary to diagnose poor running.
Rex
1975 911s and 2012 Range Rover Sport HSE
1962 BMW R50/2, 1995 BMW R1100RS
Old 12-31-2017, 02:52 PM
The ‘77 distributors are vacuum retard. I don’t notice a difference with it hooked up or blocked. Mine had a red cover/ plug fitting on the port that the hose hooked up to blocking vacuum when I bought it. Ran it that way for twenty years until I noticed it and removed.
Like I said, no difference in my experience.
Rutager West
Old 12-31-2017, 03:17 PM
The AAR will put a ďtonĒ of unmetered air into the system if it isnít closing once the engine warms up. You could try to block and cap the hose and valve once the car warms up and see if it isnít closing.
Rutager West
Old 12-31-2017, 03:22 PM
Since your running issues started with cooler weather, I would get a CIS gauge set and check, warm up regulator pressures. With time the regulators become too lean. Many posts on this issue. Rob
Old 12-31-2017, 03:25 PM
Nope.......
RWest,
The air passing through AAR is all metered unless you have a hole or crack on the vacuum line.
Tony
Old 12-31-2017, 03:39 PM
Originally Posted by boyt911sc View Post
RWest,
Tony
Yes, youíre correct, my error.
It does get the air off the boot after the fuel distributor, so metered; not sure where my brain was earlier.
Rutager West
Old 12-31-2017, 04:38 PM
Bill Verburg's Avatar
'77 was the first year for the Warm up regulator thermo valve, make sure that this is working right first
Bill Verburg
Old 12-31-2017, 05:14 PM
T77911S's Avatar
thermo valve and vacuum line form WUR to throttle body.
make sure the is vacuum at the WUR at IDLE. if not, it will not accelerate very if at all.
you can bypass the TTV, but it is very nice to have in very a vary cold climate.
for the dist.
find a vac hose with vac on it at idle. connect it to each of the ports to determine which one is advance and which is retard.
vac retard has vac ONLY at idle.
vac advance ONLY has vac above idle.
you can look at the TB and see which ports are above and below the plate, when closed.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 01-03-2018, 08:52 AM
A 77 only uses vacuum retard to meet idle emissions. There is no advance connection until 1978 which was the first advance
Bruce
Old 01-03-2018, 09:01 AM
