Savage's Avatar
Leaking chain cover after update
Just did updated tensioners on the 83SC and all went well. After I finished I have a small oil leak out of the left chain cover from around the lower 3 nuts. I used a cross tightening pattern when I put them on but it hasnt stopped it. Two questions, is this pattern correct and what is the torque values for the nuts on the cover.
Scott S
83sc
www.pelicanparts.com/gallery/Scott_S/
Old 02-17-2003, 09:35 AM
Were the gasket sealing surfaces completely clean of old gasket material and ungouged? Sometimes old gasket material remains right next to the studs (since it's hard to scape there - use only a plastic or wood scaper) and causes a leak. Was the cover flat with clean, ungouged sealing surfaces? The nuts should only be torqued to 7 ft-lbs (84 in-lbs). I also apply a very light coating of Curil-T compound to the paper chain cover gaskets. Cheers, Jim
Old 02-17-2003, 11:16 AM
Savage's Avatar
Jim the covers were clean and straight. I am going to remove them again and check how clean the area around the studs were. Thanks
Scott S
83sc
Old 02-17-2003, 11:54 AM
