Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
proporsche's Avatar
ok, i believe you but he does not know that on oil cooler should be nut and a spring washer?Not old(reused) nut with alu washer....anyway really how did you look on your engine top for the oil leaks?
Ivan
Old 01-01-2018, 03:01 PM
proporsche's Avatar
Do some study you can work on your 911 by your self.
In these days you will find a lot help online.To remove the oil cooler you do not have to remove the engine ,just for the starters...
Ivan
btw ,poor work is correct he did not even clean the engine after he worked on it?? that is always big no no ...!!
Old 01-01-2018, 03:03 PM
I have a feeling that this is my issue, I cant see in there though.
Jimmy Foster
78 911 SC
Old 01-01-2018, 03:04 PM
proporsche's Avatar
Another q i have why is your oil line cut and plugged?
And ,lube the clutch arm and spring looks way to dry...to me...how is your clutch pedal, is it hard to push?
Ivan
Old 01-01-2018, 03:11 PM
Ivan
What is This oil line that is cut and plugged? Anyone have a picture of what it supposed to look like? That line goes into the exhaust, I imagine thatís the old air injection line
Old 01-01-2018, 03:46 PM
My clutch is good and feeling except for chattering
Old 01-01-2018, 03:47 PM
Pic for attention
Old 01-01-2018, 03:50 PM
proporsche's Avatar
can you follow the plugged line and take a picture from bottom?
Old 01-01-2018, 03:57 PM
83 911 Production Cab #10
JJ 911SC's Avatar
No but the guy that replace your oil cooler should have. Ask him about it.
Who Will Live... Will See
Old 01-01-2018, 04:04 PM
Hey, nice marmot.
tirwin's Avatar
Tirwin ,where the heck did you hear about the green o rings being bad.These types are the only o ring you should ever use on Porsche 911 engines.
If you click on his garage you would know what year is his 911 also being there EGR pipe for air injectors makes it either 1978 or 1979..
Ivan
It was discussed here.
It’s not hard to say what year when posting a question or put it in the sig either.
Happy New Year.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 01-01-2018, 04:07 PM
Itís not hard to say what year when posting a question or put it in the sig either.
Happy New Year.
Are you talking to me? My year and make is in my signature line is it not? Itís a 78 SC
Old 01-01-2018, 04:25 PM
proporsche's Avatar
2stroke, yes you are absolutely correct about your signature alias garage.....he was talking to me but he forgot to read what i have written to him....;-)
ivan
Old 01-01-2018, 04:30 PM
I let it run in my garage for about 30 minutes at 2500 RPM and did not really leak until I turned the idle down and then shut it off and now itís dripping pretty good
Old 01-01-2018, 04:48 PM
proporsche's Avatar
well,there is a way to look inside the space behind the cooler.I have a very small mirror about 1cm diameter,i used to use it for this kind of investigation..it is a mirror dentists use.Again how do you know your top of the engine is not leaking ?
ivan
just remembered that pipe which is plugged is your EGR pipe.Never mind.leave it like it is.Or ,take it of the exhaust system and find a ball from cv joint bearing .That ball will fit there and use the existing nut to tighten the ball into the exhaust pipe.Cut the pipe of and the nut which is on the crossover piece use with the ball from the bearing from axle joint.
here
Old 01-01-2018, 04:58 PM
Hey, nice marmot.
tirwin's Avatar
Not talking to you.
Old 01-01-2018, 05:18 PM
Hey, nice marmot.
tirwin's Avatar
ivan
Sig and garage are not the same thing. I donít take the time to look in everyoneís garage because not everyone uses it. Why make people do extra work? Whatever.
Old 01-01-2018, 05:20 PM
JJ 911SC's Avatar
I let it run in my garage for about 30 minutes at 2500 RPM and did not really leak until I turned the idle down and then shut it off and now itís dripping pretty good...
That narrow it down, leaking when there is no oil pressure.
Old 01-02-2018, 01:31 AM
What do you think this means?
Jimmy Foster
78 911 SC
Old 01-02-2018, 03:02 AM
proporsche's Avatar
hi..i am going to ask you once more..how did you check the engine top ?You said it is not leaking?
Ivan
Old 01-02-2018, 04:24 AM
Ivan
with my mirror. plus..... my mechanic just had the motor out on the floor a month ago. all is clean on top.
Jimmy Foster
78 911 SC
Old 01-02-2018, 06:02 AM
