So wait ... What is the duck tape for again?
Old 01-02-2018, 06:34 AM
proporsche's Avatar
is it the same mechanic who sold you the oil cooler and you still have an oil leak?
Ivan
Old 01-02-2018, 07:02 AM
yep, same guy, I searched and the consensus was that the motor will have to be pulled to get the oil cooler out. I don't really want to, but I guess that I will tackle that job on my own this week. I did see the motor on the ground myself, and the top is clean.
Jimmy Foster
78 911 SC
Old 01-02-2018, 07:30 AM
proporsche's Avatar
Before you do pull he engine out do one more thing.
Get your self a carburetor cleaner and clean the area you see the oil. Then wipe totaly dry and run the engine as you did before but not that long ...Double check a get ready for the job...Make sure you unplug all you have to.Also don`t forget on your trany back up light switch wire with two connectors,disconnect heater hoses....among other obvious things.If you need some guidance let me know i will write some tuto for you.
Ivan
Old 01-02-2018, 08:11 AM
Originally Posted by 2stroke View Post
Recently took my car to the local air cooled Porsche mechanic for an oil leak, he replaced my oil cooler for lots of money.car went back to him a week later for the same oil leak, had the cracked case by the oil cooler seeping.the backside has been sealed up.
Am I reading it right that the case has been sealed up with tape ??!!!
I can't afford that.
Old 01-02-2018, 09:08 AM
proporsche's Avatar
pmax...i think 2stroke put it on him self to eliminate one place in order to find the cause of the oil leak...
Ivan
Old 01-02-2018, 09:15 AM
Update.... got it apart today.
Old 01-02-2018, 03:04 PM
The duck tape is to hold the wax JB weld from dripping out of the hole when first applied for the TSB
Old 01-02-2018, 03:12 PM
proporsche's Avatar
hi 2stroke..perfect job ...looks like you know your way...so the culprit is the one from the inside plug..
congrats
Ivan
Old 01-02-2018, 03:16 PM
congrats
Ivan
Yes, it looks to me as if it was leaking behind the oil cooler.I have JB Weld on it now with a piece of duct tape setting up .
Old 01-02-2018, 03:27 PM
83 911 Production Cab #10
JJ 911SC's Avatar
What is that?
Who Will Live... Will See
Old 01-02-2018, 03:30 PM
proporsche's Avatar
jj..that looks like old dirt mix with some oil...Which the mechanic who just replaced the oil cooler did not bother to clean and mainly did not put JBweld on the plug..i guess he does not know about this problem?
Ivan
2 strokes, i did asked you..did you get the old cooler back..was the oil leak before the replacement the same?i wonder if your old cooler was leaking at all?
Old 01-02-2018, 03:40 PM
JJ 911SC's Avatar
jj..that looks like old dirt mix with some oil...Which the mechanic who just replaced the oil cooler did not bother to clean and mainly did not put JBweld on the plug..i guess he does not know about this problem?...
Ivan
I was afraid it would be that...
2Stroke
I guess you know never take you car back to this guy. Some of that dirt if close to the large O ring joint.
The fix should look like this:
Old 01-02-2018, 04:05 PM
Thanks for posting the picture of the completed repair J.J. I couldnít figure out exactly what had to be filled and had heard of the problem before without knowing what was needed.
Rutager West
Old 01-02-2018, 04:45 PM
proporsche's Avatar
rwest :if you look at post number 7 i did explain it there;-)
Ivan
Old 01-02-2018, 11:59 PM
Ivan
Thanks Ivan, that had me almost there, but then seeing the completed repair brought me completely up to speed.
Rutager West
Old 01-03-2018, 01:11 AM
proporsche's Avatar
Hi Rutager..you know what is interesting.?.This problem has been there (mainly on the earlier models of 911) but Porsche came up with bulletin in late 1989...a little late i say..
Ivan
Old 01-03-2018, 01:30 AM
Originally Posted by JJ 911SC View Post
Ivan
2Stroke
Iíve been trying to understand how this fix work since I will be removing my oil cooler soon and this explains it nicely for the first time.
Thank you for this.
1976 911s targa
Old 01-03-2018, 07:50 AM
Correct.... he will not be seeing me car again. I can do the work myself, sometimes I just donít want to. I did get the old cooler back. At the time he did send me a video of him pressure testing the old one, and it showed a leak. But who knows????
Old 01-03-2018, 10:59 AM
proporsche's Avatar
You can do the test it your self ...it is not hard to figure it out how to do it.I am sure somewhere here might be tuto....also i believe somewhere in California is a shop who used to repair these...any way good job...fixing it your self;-)
Ivan
Old 01-03-2018, 11:10 AM
