Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
can a cam chain jump teeth and still turn over?
As the title suggests, is it possible?
I ask as i have experienced a sudden drop (disappearance) of compression on all cylinders.
Engine turns over, i have spark, i appear to have fuel (smell/wet plugs/fuel pump working) but have no start. I'll do a CIS system pressure test shortly but the drop in compression is my big concern.
The car is a ROW 1980 911SC i imported from japan. I have had it about 12 months but driven it probably 5-6 times as it isn't yet registered. As part of the import process here in Australia, we need to get Australian Design Compliance. Before driving it to the tester i checked the compression on all cylinders, and got a 125-130psi reading on all cylinders in (dry and cold). I assume it would be higher if wet and warm. Ahem.
I drove the car to the compliance assessor who in the process of assessing it needed to drive it. They called suggesting it wouldn't idle under 2000rpm, and then again later that it wouldn't start.
i trailered it home and it now has no, repeat, NO compression. It has spark, fuel, but no start. It turns over, and having taken the inlet cam covers off the cams are turning but no compression. I am wondering if it has had a tensioner fail, jumped a cog and now wont get compression but will turn over and not start.
Intuitively this seems unlikely, as a valve would hit the piston to stop it turning over. But i cant explain the no compression, the lack of starting with fuel and spark.
Old 01-02-2018, 03:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
A tensioner failure on one side would not affect the other bank. Could have been over-revved and bent all the valves. There would be a lot of extra valve clearance on the bent ones if that was the case. Pop the other covers and go through the adjustment procedure one cylinder at a time. No need to use a feeler gauge for now, just work the rockers by hand and see if any are really loose. Really tight isn't good either obviously, got to have at least .004 clearance.
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 01-02-2018, 06:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
analogmike's Avatar
I had this happen on one bank, due to a crankshaft oil plug that came out and jammed in the chain (I guess). I noticed the engine lost power before it lost oil pressure. Broke a bunch of rocker arms and the engine needed to be rebuilt
Regards, mike AnalogMike at aol.com
1973 911RS Clone F class, 2008 GT3 cup GTC4
2004 Touareg, 2006 Mini Cooper S, '01 Viper GTS
my racing pages - http://www.analogman.com/911
~^v^~ aNaLoG.MaN ~^v^~ guitar effects LLC www.analogman.com
Old 01-02-2018, 01:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Functionista
manbridge 74's Avatar
No way would I have let them drive it w/o me there. Sounds like they money (yours) shifted it.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-02-2018, 07:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Under the radar
Trackrash's Avatar
Location: Sebastopol, The Republic of California. Land of wine and redwoods.
Do a leak down.
Wouldn't hurt to check the cam timing, but as said, sounds like bent valves.
Gordon
_____________________________________
'71 911 Coupe 3,0L outlawed
Old 01-02-2018, 07:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
I feel sick thinking about it.....
Old 01-02-2018, 10:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
It's a 914 ...
stownsen914's Avatar
Any recourse against the agency and the genius tester who did this to your engine?
Old 01-03-2018, 04:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
We're just ass-u-me ing right now, until further inspection.
Old 01-03-2018, 06:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
T77911S's Avatar
if the timing has changed, one side will be different than the other, if low compression do a leak down to check for bent valve or do as JW said.
125-130 is low. could be your tester?
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ [__] RUNNING: [__] NOT RUNNING:
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[] RUNNING:[_] NOT RUNNING:__2000 MER E320 WAGON [_] WRECKED:[]RUNNING:
Old 01-03-2018, 07:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
In reality, if there is no compression, the valves are all bent. Before coming to this awful conclusion, I would check your compression gauge first.
Old 01-03-2018, 02:33 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Agreed a leak down would be the next check, as well as checking valve clearances for bent/damaged valves.
I had previously looked at doing a leak down but couldn't get to the crank pulley nut to turn it to TDC (engine mount give no clearance with a two belt pulley)
Anyone got a tip on turning the thing over ?
cheers
Ben
Old 01-03-2018, 04:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
cheers
Ben
Put your socket on the upper pulley; you may need to put pressure on the back side of the belt or squeeze it together if it slips when you turn it.
Rutager West
Old 01-03-2018, 05:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Put it in 5th gear and push the car forward.
Rex
1975 911s and 2003 BMW M3
1962 BMW R50/2, 1995 BMW R1100RS, 1979 Yamaha RD400F (sold)
Old 01-03-2018, 05:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Push in on the right side of the belt as you crank the alternator nut clockwise.
Old 01-03-2018, 06:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
