Non-metallic slate gray on a midyear
Thanks to a minor fender bender my 74 is finally going in to be repainted. I believe I've settled on a non-metallic gray, specifically I think I'm close to zeroing in on a slate gray.
While the car in the picture that I've attached is clearly not a midyear car, my 74 does have bright work on it that would probably also pop like in the picture below. Can I ask if that looks like a Porsche Slate Gray to your eyes? I know color matching off Internet pictures is dubious at best, but trying to make sure that I'm clear on what the colors look like. Anyone have a midyear that they painted this color? Thank you and best wishes for a happy new year to all http://forums.pelicanparts.com/uploa...1514912710.JPG |
I've always loved that shade. My very first VW ('64) was very similar (if not same) color.
Go for it. |
I'm going for the same combination at some point (non-metallic gray and brightwork trim).
I want something a shade or two darker than that. Dodge Challenger "Destroyer Gray": http://forums.pelicanparts.com/uploa...1514913897.jpg Ford "Lithium Gray": http://forums.pelicanparts.com/uploa...1514913932.jpg New, Ford "Lead Foot Gray": http://forums.pelicanparts.com/uploa...1514913962.jpg There's also some old Mercedes colors that I've seen in person and fell for... 124G Arabian Gray: http://forums.pelicanparts.com/uploa...1514914190.jpg 173G Anthracite Gray: http://forums.pelicanparts.com/uploa...1514914205.jpg |
I think Toyotas "cement" paint color would look good as well.
Good morning Charles, thanks for the note back. I noticed that you also own a 1974!
Thanks for those pictures Mike, all variations on a very similar shade. I like those too.
I did come across the Toyota cement color, I actually had a chance to see that color in person and it may have just been the lighting on that day but it had more blue undertones in it than I expected from the pictures. It did suit the truck that it was on, also quite handsome. Thanks! |
Steve McQueen's 76 930 was painted Porsche 356 Slate Gray by the factory which is a different mix than later 911 Slate Grays.
Just a data point. It has a little green in it. There are several threads out there on it, including the mix. http://forums.pelicanparts.com/uploa...1514936166.jpg |
I would definitely stick to the 66/67/68 original Porsche Slate Grey. Post 62 below.
The Definitive Color Thread |
Thank you for the discussion, pictures and links.
Yes a '74 Targa. I'm jealous of your 3.2 though....I'd love go go that route. On paint colors - mine was originally metallic silver, which I rather like. But it's been color changed at least twice so switching back to original would be much more than I can afford to do correctly. So, my plan is to fix a couple of rust areas and shoot it with Zolatone : http://forums.pelicanparts.com/uploa...1514949832.jpg It's a multi color paint that has a rough texture. No worries about rock chips or small dings or dents. Some day when the budget allows I'll do a proper restoration back to Met. Silver.... Cheers, -C |
Nice car.
That looks to have some metallic in it, no? |
http://forums.pelicanparts.com/uploa...1515425573.jpg
Heres my slate gray 75 |
Thanks!
That's almost a gunmetal blue. Very nice.
You can't go wrong with Slate Grey. I started a thread about non-metallic greys: http://forums.pelicanparts.com/porsche-911-technical-forum/918016-need-inspiration-show-me-non-metallic-grey-colors.html
You can find some inspiration there as well. A friend of mine had his car painted Porsche Grey Black. It is a newer color and darker than Slate Grey. Good luck with your choice. https://cimg5.ibsrv.net/gimg/rennlis...c57fc7cb5b.jpg |
Yes grey-blk is a nice choice. Did my 964 in that color.http://forums.pelicanparts.com/uploa...1515522144.jpg
Thanks guys, I'll go check out that other thread.
Have people been happy with the current paint formulations getting the color right? |
| All times are GMT -8. The time now is 06:24 AM. |
