fetus's Avatar
Question Reusing stock 19mm torsion bars?
I want to switch from 21mm torsion bars back to stock 19mm torsion bars.
I see a lot of them for sale. Some rusted, some pitted. Should I be worried about future breakage?
75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts.
Old 01-06-2018, 07:53 AM
cycling has-been
bkreigsr's Avatar
Should I be worried?
Yes.
Surface rust can be cleaned up and repainted.
Otherwise, deep pits and heavy rust will have compromised the integrity - stay clear.
Bill K
Old 01-06-2018, 08:19 AM
Agree. Plus you need to know which side the t bar came from and install on same side. Torsioning against the grain will shear the bar for sure.
Old 01-06-2018, 08:38 AM
cycling has-been
bkreigsr's Avatar
All the stock 19's are marked L/R at the factory.
Old 01-06-2018, 09:18 AM
fetus's Avatar
Thanks for the help!!
Old 01-06-2018, 11:30 AM
fetus's Avatar
I already have an offer on a pair of used 19mm torsion bars. My current 21mm torsion bars are for a 914-4, so they won’t fit a 911. I bought a pair of used 911 “A” arms just to support the 19mm torsion bars.
It might be a month before I get around to this project, so the 21mm torsion bars are not currently for sale.
I’m starting to get PM’s on future left over Parts...
Old 01-06-2018, 07:32 PM
fetus's Avatar
Is there a big ride difference between 19mm torsion bars and 21mm torsion bars?
Old 01-07-2018, 10:18 AM
cycling has-been
bkreigsr's Avatar
Depends on what you've got going on with the rest of the suspension.
If the rest of your suspension is stock, and has xxx amount of miles on it, you will feel a big difference in ride quality.
If the suspension has been modified with bigger/stiffer goodies, the ride difference will be less noticeable, as it should already be kind of 'sporty'.
YMMV
Bill K
Old 01-07-2018, 12:32 PM
