Sway bar Q...2mm difference?
I was wondering if there is a significant difference in handling of upgrading sway bars by 2mm. The stock sway bar size on my car is 20mm front and 18mm rear. If I swap to 22mm fronts and 20mm rears, will I notice any difference on the track? I acquired this set from an RSA.
John
1997 993
2012 991
Old 09-04-2003, 06:31 AM
Yep, that'll make a difference. The outside of the torsion bars and swaybars are what do most of the work which is why drilled torsion bars work.
Old 09-04-2003, 06:47 AM
Certified Pre-Owned
BGCarrera32's Avatar
Try this, unhook your sway bars and go for a drive. Pretty dramatic diff. So it is conceivable that you would notice a 2mm diff. I upgraded my Carrera from 20/18 to 22/21, quite noticeable...
-BG
'84 Carrera Coupe
Old 09-04-2003, 07:06 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Don't remember the details, but in my suspension book that i read, for every unit increase in diameter the torsional value increase exponentially. Although i can't remember off the top of my head whether it was cubed or squared. Either way each incriment that's increased is a big difference.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-04-2003, 07:10 AM
Here, this doesn't exactly relate to our cars, but it does show the difference when small changes are made.
http://www.tsimportedautomotive.com/Swabarra.html
Old 09-04-2003, 07:17 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
I noticed a big but reasonable difference when I went w/ 22/21 bars on my SC.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 09-04-2003, 07:21 AM
Chuck Moreland's Avatar
Stiffness of a torsion bar increases with the 4th power of the diameter! So small size changes make dramatic spring rate changes.
Spring Rate = (D^4) X (Spring constant)
Going from 20mm to 22mm yields a 46% increase in stiffness, for a 10% increase in diameter.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-04-2003, 07:55 AM
1fastredsc's Avatar
2007 Mazda 3 hatch
Old 09-04-2003, 08:07 AM
Wow, thanks for the replies. I'll definitely be under my car tonight doing this r&r!
Thanks again!
John
1997 993
2012 991
Old 09-04-2003, 08:15 AM
Chuck, is this same w/ a sway bar? I assume it would be but does the length have any effect on it?
I would probably answer my own question if I just did the math.
'81 911SC Targa 3.6
1fastredsc's Avatar
Longer length decreases it, but not at the same rate that a larger diamter increases it. Also, with sways that have bends at the end (like factory i believe) as opposed to splined lever arms, the bends produce a little of there own spring effect. That i do remember from that book, i should scan the formula portion of that chapter, really interesting.
2007 Mazda 3 hatch
Old 09-04-2003, 08:23 AM
