-   -   Rear window defog, two settings? (http://forums.pelicanparts.com/porsche-911-technical-forum/9837-rear-window-defog-two-settings.html)
tbitz 10-31-2001 09:03 PM
My rear window defog switch has two steps. Does anyone know what the difference between the two steps on the switch are? (My users manual is in German)
Tony
'78 911SC
Bobster 10-31-2001 09:10 PM
I have a 1977 Turbo with two switch positions first position is first stage on rear window (150 watts)and also the windscreen the second stage is double the watts for the rear window only.. also actuating the switch in either position also activates the heated outside mirrors..hope this help
R22tech 10-31-2001 09:52 PM
pull switch=defog
pull switch then turn=defrost(i.e. fully energized element)
Jack Olsen 10-31-2001 10:23 PM
Two steps for the defog is like the "coolness" dial on the AC. When on earth does a 911's AC system get the car too darn cold? And when does it get rid of fog or ice on the windows so quickly that you want to pull it back a notch?
In my opinion, a simple on/off switch for each would be more honest.
Jack Olsen
My Rennlist pageMy Pelican Gallery pageMy Porsche Owners Gallery page
[This message has been edited by JackOlsen (edited 10-31-2001).]
Nickshu 11-01-2001 04:46 AM
I think....
that turning it to the right activates only the center defrost lines (the ones you would need to minimally see out)...devoting all the power to these 5-6 lines to defrost the line of sight quickly.
Pulling it out activates all of them evenly, with less power since it is distributed thru all the lines.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
jsmarcus 11-01-2001 05:40 AM
Mine just stopped working, so I can't tell you for sure. But it did work.
Turn--defog includes mirrors
Pull--defrost
According to the '84 manual.
Josh
'84 Carrera Coupe
tbitz 11-01-2001 09:47 AM
Thanks guys.
It looks like Nikshu is right.
I took off all the panels in the rear. The defog lines are indeed partitioned so that the center section has its own power and the top an bottom sections have a secondary power wire. When the defog switch is pulled to the first step only the center defog lines get power. When the defog switch is pulled all the way all three sections get power.
Tony
'78 911SC
