Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Front suspension question - rubber dust covers for struts...
I'm rebuilding the suspension on my Targa and needless to say I slid way down the slippery slope. I'm shedding the original metal dust covers looking to replace those with rubber bellows. I see that others have done something similar.
I acquired some boots which presumably would attach to the lower body of the strut (below the gland nut) and attach to the rod up near the upper strut mount.
Question: How do you deal with strut rotation during steering? Does the boot just twist? Or does one end need to slip/rotate?
Old 01-13-2018, 05:16 PM
devalued member
juanbenae's Avatar
with the accordion nature of any rubber dust cover you might implement as long as they are secured well both top and bottom, not fitted to tightly steering range should be of little consequence.
caster steering angles are less that *45 on full lock in our cars. the rubber should twist accordingly,, pun intended...
75S slick-lid webered 3.oL hotrod/lightweight/outlaw/bastard/NoGruppe sorta thing
07.5 2500HD GM Diesel 4x/93 Wrangler YJ
08 DRZ400SM+FCR Mikuni
78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 01-13-2018, 05:32 PM
Thanks. I might be over-thinking this (and it is the reason I'm asking) but I've never seen a rubber accordion-style bellows do well with torsional displacement (they're made for axial displacement).
Old 01-13-2018, 06:52 PM
After thinking about this one for another day: Has anybody made anything like a carrier bearing to place at the top of the strut so the bellows doesn't have to rotate? (There I go overthinking it again...)
Old 01-14-2018, 07:12 PM
Only photo I could find:
Generic 4x4 dust boots. I don't even have them zip tied anymore. Mine don't get sandwiched between the strut top and the camber plate, so they are free to rotate there. Pretty soft / squishy rubber so they rotate pretty easily anyways. Aka, you're overthinking it.
Matt - 84 Carrera
Old 01-15-2018, 04:22 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
There's a VW boot from a 2000 generation Jetta that fits fantastic at both the top of the damper shaft and the bottom of the strut body. I've used these before and I just left the boot loose at the low side.
It's part number 357-413-175-A-M36 and you can get it here from Pelican. $4.25 each for the Febi Bilstein brand and there's three others to choose from- Genuine Audi VW, Meyle and Rein
Kevin L
'79 911SC widebody conversion
'86 Carrera
Past: '87 Carrera "The Unicorn"
Old 01-15-2018, 07:43 AM
Air Cooled
Craig_D's Avatar
I used a VW gaiter:
VW B3 B4 Passat Front Strut Boot 1993-1997 Suspension Dust Bellows 357413175A
'78 SC Elephant Racing Suspension Rebuild
'78 911 SC "Blackjack" & '76 914/4 "Blue Hornet"
2012 Ducati Multistrada S, 1994 Ducati 900SS LWCR
1990 Honda Hawk GT, 1988 Honda Hawk GT,
1977 Honda CB750K Cafe
Old 01-15-2018, 09:24 AM
Thanks guys. (Craig - I've been referring back to your thread quite often.)
Old 01-15-2018, 08:53 PM
