Barn find LWB 911, now what to do with it.
Hi,
I’m a new member and this is my first post. I just bought a 1970 911 Coupe from a friend. It was driven into his shop years ago and disassembled and has been sitting ever since. After a little detective work it appears to be a US Model 1970 911T Karmann Coupe w/5-speed and A/C. VIN: 9110121981 Engine: 6106948 Engine Type: 911/07 Transmission: 7115686 Transmission Type: 911/01 The good:
The bad:
The interesting:
So the question is... What should I do with it? I have written Porsche and asked for a CoA with the engine/transmission numbers. Are the plaques available from anyone? Restore it or Hot Rod it? I have a 1997 3.6L VarioRam engine with 41k miles. That bolted to a built 915 gearbox w/good ratios and a limited slip could make a really fun car. Either way I think the body should be brought down to metal and the car completely refinished. Something I am capable of doing. What do you guys think? More pictures here: https://drive.google.com/open?id=1_Z_eIm_yv9HewPpmNuOvbdC5u9jxP9VU ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Eva
I'd go with it's a 911T...considering that's what the dash says...but only numbers and research would tell if you cared.
Looks like a serious recipient for a V-Ram. Moth ball original paperweight
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Is it safe to post the vehicle numbers? Here?
I have nothing to hide I've just never done it before. |
Registered Minimalist
Here's what you should do:
Put it back together and drive it! And document your journey for all of us to see. :-)
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Eva
Worst that could happen is someone knows more about the car than you do
Vehicle numbers added.
'70 T should be 911010xxxx or 911012xxxx for a Karmann
Looks like you are correct with the info as a '70 T Karmann, engine number also looks correct for a '70T engine Transmission looks like a 5spd from a '71 Last edited by jrbennett; 01-10-2018 at 06:10 PM.. |
Nice find!
gearhead
Check that rear decklid and see if it is steel or aluminum. If aluminum it’s an S lid and worth thousands. The car is a T. But it might have a few nice S Parts.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
The deck lid might be aluminum as a magnet will not stick to it.
Under the radar
Nice find.
Take a look at the motor. Use a magnet on the cylinders to see if they are aluminum or iron. T motors had cast iron cylinders, those appear to be aluminum (biral). It looks like they only did some weird paint on the front bumper. It looks to be original, as does the hood latch panel, which is awesome. If it is the original motor, with the price of long hoods now days it makes sense to keep it as original as possible. At any rate, keep the body original regardless of your plans.
It looks to be (fairly much) rust free. So you are WAY ahead of the other guys who have done a barn find.
Good score! |
To do most things properly you'd have to drop the engine and trans to reseal - so it's good it's already out. It doesn't look that bad at all.
Cool find, and enjoy the journey wherever it may lead!
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
What's with the rear bumpers? Nice find.
Did you get the memo?
Very cool, congrats! Considering the money that longhoods are bringing, I would be hard pressed to invest the money required for the inevitable restoration and not return it to nearly stock. Maybe stick the 3.6 into a cheap SC instead if you want a hot rod. But if the long term value of the car isn't a huge concern, go for it! Either way it looks like a great starting point.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
I have done a number of these cars
restoration = $$$$$$$$$$ If you just want a fun car, hot rod it and enjoy it Ed |
So I heard back from Porsche. The engine is the original but the transmission is not. Strange thing about the engine, per Trackrash I put a magnet on the cylinders but it does not stick. So that’s a little confusing as the engine appears to have never been apart. The cylinder heads are all dated 10•69 except for one that is 9•69.
The carburetors are Webers, I thought they were supposed to be Zenith or Solex. Is the front bumper the original? It is not steel. The rear bumper is steel, but is from what? The tail lights and rear reflector are in perfect shape but are obviously the wrong year, what year are they? The decklid is aluminum. The window trim is black, is it from another car? Painted over? All of the factory plaques are missing and presumed lost are those obtainable anywhere? Apologies for all the questions but, I know nothing about the older cars. Last edited by CPS996; 01-22-2018 at 01:07 AM.. |
Under the radar
The engine numbers indicate it is the original motor. So I'm guessing someone updated the motor at some point. Possibly S cylinders and pistons? So until you tear it down you won't know what's in it. With the 2,4 S emblem, who knows?
That rear bumper center piece and center reflector were an available bolt on "upgrade" back in the day. The front bumper is a fiberglass replica of an S style bumper. The US T models had Zenith carbs originally. The window trim was most likely pained over. Try some paint stripper to find out. The aluminum deck lid is worth $$$. Might be worth selling to recoup some money. There are reproduction and NOS plaques available.
Ubi bene ibi patria
Good luck on a good score.
Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
| Tags |
| 1970 , 911t , barn find , lwb |
