Help ID this piece please!
What do you call this cardboard and steel piece that bolts over the components that are attached to what would normally be known as a firewall, and what years 911 is it for? I have one for sale.
It has male snap receivers for the carpet to snap onto. Here's a photo of the part at the back of the trunk... ![]() ... and here's a photo of the part removed from the car
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 01-17-2018 at 07:54 AM.. |
It's called a blower cover. Pelican sells a reproduction part - APBZ-BC7789, for $349.
The part is interchangeable over a range of years. https://www.pelicanparts.com/More_Info/APBZ-BC7789&SuperCat=Y&SVSVSI=.htm
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Rennline also sels a replacement option for $100
1984 Carrera 3.2 Cabriolet |
Earthling
Luggage compartment trim
911-551-067-05, $201 from certain online porsche dealers Position #29 in the diagram (From 79 to 83 SC but may apply to other years also)
1996 Porsche 993 C4. His 1979 Porsche 911SC - sold... and now BACK again! Hers 2021 Volvo V60 (foul weather drive) 2024 Volvo XC60 (spousemobile) |
Thank you gentleman, I appreciate your help!
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I replaced the cardboard piece on my car with a piece of alucobond . Alucobond is a blend of aluminum and plastic in any color you want. I bent it to match the curve of the steel bracing and cut to match. Used the same material to replace the old plywood pedal covers as well. You can get it from sign companies, they use it to cover architectural walls and make sign boxes with it.
