-   -   Front spindle clamping nut (http://forums.pelicanparts.com/porsche-911-technical-forum/984807-front-spindle-clamping-nut.html)
Forssling 01-20-2018 03:56 AM
Hi All, I'm restoring a 71 911T. When I bought new front struts I had to upgrade to 3.5 inch caliper spacing.
Now I'm noticing that the front spindle clamping nut does not fit. I obviously need a bigger one than my original.
Just want to check my sanity before I look for the right size. The PET states two sizes, M16 and M18. It's kinda obvious that I need the M18 but an anyone confirm the above.
Thanks as always,
Jörgen Forssling
Göteborg
SWEDEN
bkreigsr 01-20-2018 08:04 AM
1965 - 1973 is part number 914 341 671 00, or 16mm with a 1mm pitch.
1974 - 1989 in 911 341 673 00, or 18mm with a 1mm pitch.
The only other part that will not match is the outer bearing washer - you'll need a new pair of these. (911 341 663 00)
Those referenced years should be taken with a grain of salt, as the early cars fitted with the 'S' calipers also had the 3.5" spacing.
Bill K
Forssling 01-21-2018 03:48 AM
Thanks!
//Jörgen
