Revive a 2.7 after 20 years
After many years it is time to get it back on the road. What to do? I don't know why the car was parked. Family vehicle but most information died with the owner. 1976 2.7 original engine. About 78k miles. What is the checklist for the engine?
I assume the fuel system is shot. My concern is I see many bad things about the 2.7. How can I check to see why it was parked?
In no particular order I will address
plugs
wires
spark
fluids
filters
exhaust check
compression
fuel-as stated above
most importantly the radiator and antifreeze flush---------kidding
Any advice would be appreciated Thanks
Old 01-20-2018, 06:43 PM
Pull bottom valve covers and see if there is broken or pulled head studs would be my first thing to do on my list.
Old 01-20-2018, 07:17 PM
Functionista
manbridge 74's Avatar
Leak down test would be up there...
Entire fuel system will need attention from tank to injector tip if it wasn’t stored dry.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-20-2018, 07:28 PM
HarryD's Avatar
Read posts 20 and 21 of this thread. Ignore Grady at your own risk.
Winter storage checklist?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-20-2018, 08:02 PM
Bill Douglas's Avatar
What fun. Keep us posted and some pic's of the car please. We are right behind you in getting this thing going!
Old 01-20-2018, 08:56 PM
Had the privlage of reviving a '76 after a 15yr storage. Found that the fuel residue in the pump and both lines (supply and return) had turned SOLID. Like rock candy. Good luck.
Old 01-20-2018, 09:02 PM
It is still patiently waiting on me to get my game plan together and dive in. Thanks for the advice. Additional info is welcome.
Old 01-21-2018, 07:34 AM
Welcome to the forum. Post some pics of the car when you get a chance.
I highly recommending doing a bunch of research and developing your checklist before doing anything. A 2.7 is already expensive to fix; a broken one more so.
One suggestion I'll add is to do a very good visual inspection (go get a USB borescope if needed) of the cylinder internals, under the cooling shroud, in all the nooks/crannies, etc. I resurrected a '75 Targa and found numerous instances of rodent intrusion (chewed, leaky fuel lines, insulation removed from a primary battery cable, nest, dead baked-on rodent carcass, etc).
Old 01-21-2018, 07:49 AM
78 sc
Here is what I had to d to get mine back on the road:
New fuel tank (orig one was so gummed up, would have had to cut it apart, clean it up and reweld. New tank was the economical choice
New fuel pump
Blew out fuel lines (with engine sides disconnected
New fuel filter
New accumulator (recently)
Fuel dist was rebuilt
Pop off valve installed
Fuel injectors had a great pattern and flow rate so nothing more done on fuel system
New air cleaner
Plugs only had 65 miles so I left them. (I have since replaced)
New cap and rotor
New tires
New brake lines and fluid
New battery
After getting it started, learned I had 8ish broken head studs so motor removed and tear apart begun. Great learning process
I have put about 25xxx miles on her since then. Up to 33xxx miles now
Good luck and post any and all questions here. (After searching first, of course). This is a great resource with amazing advice.
Old 01-21-2018, 07:53 AM
