Tom '74 911's Avatar
Engine tin powdercoating - use hi-temp powder?
Hi -
My local powdercoater asked if they should use a hi-temp. coating for the engine cooling & surround tins... They said the hi-temp powder is about 4X the cost...
Given the threads of folks doing their own powdercoating, I'm assuming that regular powder is probably fine, but I wasn't sure, so I thought I'd ask to see what others have done.
Thanks!
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 01-25-2018, 07:19 AM
Originally Posted by Tom '74 911 View Post
Hi -
Thanks!
Tom
If u don't care what they look like in 50/m miles, what the heck>
Sent from my VS501 using Tapatalk
Old 01-25-2018, 07:35 AM
The 9 Store
I’ve had it done with regular powder on a couple engines and it still looks new, years later.
All used parts sold as is.
Old 01-25-2018, 08:16 AM
Not necessary. Most powders are cured at 400-450 degrees. If your tin gets that hot you have much bigger problems.
Old 01-25-2018, 09:12 AM
Stick with the normal powdercoating process. I have done this on over a DOZEN engines now and it still looks new years later.
If your tin is being scorched by high temperatures you have bigger problems than the powdercoating failing.
Old 01-25-2018, 09:20 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Same here. It's baked at 500+ F
That's what the factory told me but it was an industrial powder coater. Not a boutique type place.
1981 911SC Targa
steely's Avatar
Ditto - I did the fan housing and the flapper boxes a half-dozen yrs ago and they're holding up great.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-25-2018, 09:53 AM
Awesome. Thanks for the replies, I appreciate it!
Tom
Old 01-25-2018, 09:55 AM
powder coat
I bet he was talking about the ceramic coating (Jet Hot) like for headers which is 2000 deg.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-25-2018, 10:15 AM
