Topocalma
70ies antenna expert advice needed
I am trying to figure out which antennas would have been factory installed on my 1973.5 2.4T and 77 930 3.0 Turbo Carrera (both obviously US versions).
I searched exensively and found a number of suggestions in past threads: Hirschmann 6000F Hirschmann 6000U Hirschmann Auta 4900 LS 18 I also seached picture libraries of original cars (e.g. on BAT) however the antenna seems to be the least fotographed part on a classic Porsche... Thanks to all antenna fiends for your input..
1973 2.4T gemini blue 1977 3.0 Turbo slate grey 1973 2.4s motor rebuilding project |
Early 911s might have been supplied with an Auta 6000D. Since you ask about your 77 930 Turbo, here is paperwork from a similar well-preserved 77 Turbo that was supplied with an Auta 6000H. The Hirschmann instructions below include earlier Porsche models, but inclusion of the Turbo indicates that this was printed after 1975. ![]()
Jon B. Vista, CA |
Topocalma
Jon, amazing - this is exactly what I needed. Thanks!
Topocalma
http://imgur.com/gallery/OnW4K I managed to get a 6000H that is in really good shape and works perfectly. What I cannot figure out is what the two black wires are suppose to trigger and how they get connected (bottom right of the pictures). Hey seem to be connected to a kind of switch or relay and run straight out of the casing. The connection of motor to power and „radio +“ is clear and works well. Any ideas?
1973 2.4T gemini blue 1977 3.0 Turbo slate grey 1973 2.4s motor rebuilding project Last edited by Topocalm; 01-27-2018 at 11:18 AM.. |
