Sparco Steering wheel with Horn
Hi
I have a 1982 911SC that I have fitted a Sparco steering wheel. The problem that I am having is that the horn button has two connection points but there is only one wire from the contact ring behind the hub. If anyone knows what to do it would be greatly appreciated |
Undocumented User
One wire is a ground, to be attached right to the metal of the hub. The other is the the actual horn trigger. If you're missing the ground just make one.
Welcome BTW, tell us a little about you... your car.
