Weber 40 ID needed ...
After a day in a freezing barn I emerged having found what I was looking for: a pair of Weber 40's. Something I've long wanted for a 2.2 motor I'm building.
Does anyone know what year these are intended for? - I'd love more about them.
Speed has never killed anyone, suddenly becoming stationary... that’s what gets you
Old 02-02-2018, 03:57 PM
gearhead
Zoom in on the stamping directly under Weber Tipo. That will tell us.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-02-2018, 04:19 PM
Old 02-02-2018, 04:25 PM
For some reason I'm not able to ad more images (not sure what I'm doing wrong!)
The numbers are as follows: 4010TP13C and then below that 2427
Old 02-02-2018, 04:29 PM
gearhead
2.0l carbs from a 69 or 914-6. It’s 40IDTP
1974 914 Bumble Bee
2009 Outback XT
Old 02-02-2018, 04:59 PM
Matt, Thank you. Any idea if I can use these with my 2.2 successfully? - My very basic understanding is that the Weber's are fairly usable across the smaller displacement motors.
Old 02-02-2018, 06:35 PM
gearhead
According to Paul Abbott, when you go over 2l they don't transition well. I would read up on his website:
Performance Oriented
1974 914 Bumble Bee
2009 Outback XT
Old 02-02-2018, 06:38 PM
Under the radar
Trackrash's Avatar
No problem on a 2,2T.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-02-2018, 06:43 PM
Thank you Matt, Thank you Gordon.
Old 02-02-2018, 07:14 PM
1QuickS's Avatar
Those are from 1969 911T, not 914/6. 914/6 would be 40IDTP13C & C1.
Those probably have 27mm venturis, you can run them that way or install 30mm main venturis without much issue, main jets will need to be increased in size. There are ways to help transition that are not too difficult. Bolt them on & run your new motor with them & then determine what your needs are.
Check jetting of all components to know what you have before running the new motor and make sure all is compatible.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 02-03-2018, 07:55 AM
