4flyboy's Avatar
Round ignition-key cover removal?
Hi guys,
I did a search and got impatient. Can't find out how to remove the round plastic surround on our ingnition switches?
There are some tiny holes but no joy when I put an allen wrench in there?
Anyone done this?
Thanks!
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 02-05-2018, 10:35 AM
Scott, the hole is just to put something in to turn it; it has threads that turn on to the ignition piece- it just unscrews.
Rutager West
Old 02-05-2018, 10:40 AM
proporsche's Avatar
Hi Scott ..it is very easy .Just twist it left and unscrew it.It looks like this.It is called Rosette....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-05-2018, 10:41 AM
Just happened to have an extra lying about
Rutager West
Old 02-05-2018, 10:43 AM
4flyboy's Avatar
Lol, thanks guys, I take the short bus to skool.
Appreciate the quick response
Scott
Old 02-05-2018, 10:52 AM
You’re welcome, better to ask than to break.
Rutager West
Old 02-05-2018, 11:07 AM
4flyboy's Avatar
Okay, so my intent was to paint it flat black with a coat of flat clear so that I can occasionally clean it.
The paint keeps getting a mottle even after I clean and prep it.....makes me suspect something besides a plastic material?
Any ideas, came off in a Jiff btw, thanks!
Scott
Old 02-05-2018, 11:12 AM
My best guess is that thing has seen a lot of silicone based products like Armorall over its life and that’s why the paint won’t stick. Try a stronger solvent and a primer.
Rutager West
Old 02-05-2018, 11:16 AM
4flyboy's Avatar
Good counsel
Scott
Old 02-05-2018, 11:28 AM
Rennline makes an aluminum replacement
Ass-engine Nazi slot car -- PJ O'Rourke
Old 02-05-2018, 11:42 AM
Scuff it up with scotchbrite, wash with a good degreaser, dry, prime then paint.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 02-05-2018, 01:06 PM
Earthling
Brian Cameron's Avatar
Our host had some ignition switch covers but they are temporarily unavailable, might want to check these out:
Ignition switch cover | Car-Bone.pl
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 02-05-2018, 06:24 PM
Formerly known as Syzygy
Canada Kev's Avatar
Go to an auto body paint supply shop; they have plastic prep primer adhesion promoter stuff in a spray can.
Kevin
Old 02-05-2018, 06:48 PM
tobluforu's Avatar
I had the same experience, fish eye, etc. I used plastidip, not the greatest solution, but it works.
Old 02-06-2018, 03:02 AM
4flyboy's Avatar
This is what I ended up doing BR albeit with brake cleaner (again) and a light sand paper. I flirted with using the Plasitidip that I sprayed my CDR radio knobs with Toblu but, like you said, a compromise.
I primed it then sprayed two coats of flat black, looks new, no fisheye this time. I'll add a couple of coats of clear and post a picture.
I'm always amazed at how shoddy these covers look in even the nicest cars? The 911's I've had have all had that aged milky look to them. Lets down the whole instrument panel in my opinion.
Much ado about such a small thing but such an easy fix, I recommend it.
Love the support that I find here, thanks guys. Scott
Scott
Old 02-06-2018, 05:16 AM
sugarwood's Avatar
There was no need to paint it.
You can get one of those "Back to Black" products, and it works.
1986 Bosch Icon Wipers coupe.
Old 02-06-2018, 03:56 PM
Carrera 3.2 Targa
I agree with Sugarwood.
First, remove it and degrease it. I like Brake Cleaner for this. Then wipe on "Back to Black" to restore a rich original appearance.
I tighten it by hand all though there is a tool for this purpose.
Regards,
1971 911T
2016 Boxster
1988 Vanagon (crashed)
1985 Carrera Targa (Sold)
1970 VW Beetle
Old 02-06-2018, 04:38 PM
Carrera 3.2 Targa
1971 911T
2016 Boxster
1970 VW Beetle
Old 02-06-2018, 04:39 PM
4flyboy's Avatar
Thanks guys, I've used B to B on several trim pieces, I find it temporary at best. Must say that I never tried it on my ignition cover though...S
Scott
Old 02-06-2018, 08:41 PM
Alan L's Avatar
Bit late to the party , but I use circlip pliers to remove it. The expanding version - squeeze the pliers and the nose opens. Open enough to poke in to the two holes. You can loosen/tighten as much as needed. Will undo the hard to parts.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-06-2018, 09:37 PM
