Door lock release cable
While doing an interior door panel swap I ran into a problem where the lock release cable popped out of the receiver while connecting the interior door handle. Picture attached. Question, is the receiver the same plastic piece that is used on the handle connection?
Thanks Dan |
hi Dan.basically, turn the plastic piece so the hook on cable can go fully in...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
yes, if it is old replace it.They do go bad by age..
ivan
Wildman Emeritus
I think the part is nylon of some sort and it gets very brittle with age. I would buy several since they are cheap and replace all of them as you have the cards off. I also pulled the cable and cleaned and lubed it. Bit of a pain but worth the effort IMHO.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
